Won't go into Park - Dodge Cummins Diesel Forum
post #1 of 12 (permalink) Old 05-18-2019, 05:42 PM Thread Starter
Won't go into Park
1999 ram 2500 24v with 47re and for some reason the transmission won't shift into park.
cumminsbro2013 is offline
post #2 of 12 (permalink) Old 05-18-2019, 06:43 PM
NCC74656's Avatar
linkage must have slipped. nothing ot prevent you going into park aside from that. there is a small nut behind the drivers side fender, down behind teh wheel. loosen that and see if you can move the trans and shifter column in and out of all its gears. if so then just adjust and tighten back up.
99 QC,LB. full billet trans, fass 150, iquad, 37", 407Lbs grill guard, DAP VP44, Thuren coils, Thuren king shocks, DoR control arms and trackbar, 16K lbs winch, retro solutions HID. Redhead gear box, compound turbo, DAP 125's, stroker W/HO pistons, 4.10/Elocker
NCC74656 is offline
post #3 of 12 (permalink) Old 05-18-2019, 10:51 PM Thread Starter
Well...won’t go into park, will show it’s in reverse, N, D, 2,1. Doesn’t actually shift into any of those gears except for 2, and 1. Did my transmission take a crap? 161k miles. If so what do I need to buy in order to rebuild it, I’m sure it’s not cheap if I take it to a transmission shop..
post #4 of 12 (permalink) Old 05-18-2019, 11:08 PM
Killjoy's Avatar
Bro for christ sake give us some more info. I dont care what the stupid indicator on the dash says.
Does anything happen when you move the shift lever?
Were you towing 20k lbs and it made a loud bang and now wont go into park?
Did you check everything from the column to the trans?
Does it even have fluid in it?
Come on man. Help us help you.
2002 ram 2500 quad cab shortbed ST. Red, 4x4, nv4500 swap 24v, 66mm silver bullet, 100hp injectors , fass titanium 150, 4" exhaust, guages. 190k miles.
Killjoy is offline
post #5 of 12 (permalink) Old 05-19-2019, 02:44 PM Thread Starter
El no go in gearo except for 2nd and 1st, el no mattero what el stupido indicatoro on dasho sayso, comprehendo?
post #6 of 12 (permalink) Old 05-19-2019, 03:55 PM
Killjoy's Avatar
No hablo spanglish amigo. Lol
But in all seriousness, have you checked from the shift linkage on column down to the trans? There isn't much to go wrong there.
Killjoy is offline
post #7 of 12 (permalink) Old 05-19-2019, 06:25 PM
NCC74656's Avatar
if it wont go past those two gears id have to think its linkage binding or slippage. there is a detent in the column around the R to park but there is no detent on the trans. if you disconnect the linkage you should be able to move the trans shift selector (on the housing) through all the gears.
NCC74656 is offline
post #8 of 12 (permalink) Old 05-19-2019, 10:03 PM Thread Starter
Yes I can move it into all gears on the transmission by hand, but not when I hook up the shifter.
post #9 of 12 (permalink) Old 05-20-2019, 04:38 AM
Check cables, linkage and plastic linkage connectors/locks. If the plastic goes away you do not get full linkage thrust.
bigfish95971 is online now
post #10 of 12 (permalink) Old 05-20-2019, 08:18 PM Thread Starter
Is there possibly a diagram I can google, can you give me keyword to google it? New to this truck..
post #11 of 12 (permalink) Old 05-20-2019, 10:52 PM
Where the shift rods connect to each other on the side of trani(and maybe above) they snap into plastic bushings I think. (If those plastic bushings break and fall out there is too much play in the linkage and it wont go all the way into gear or park. Also if is is lose on the shaft into the trnai the half round hole can beat out doing the same thing.
post #12 of 12 (permalink) Old 05-20-2019, 11:08 PM Thread Starter
Probably worn bushings then tbh, any idea where I can other them I am sure the dodge house will say they are discontinued like most things on this truck...
Similar Threads
Hard shift from PARK... can you identify this solenoid? CentraFlo 3rd Gen. Non-Powertrain 5 04-30-2017 05:27 PM
Grinding noise when in 4LO and put in Park dbertheau 3rd Gen. Powertrain 3 06-17-2016 03:18 PM
Transmission won't go into park BlueCummins2005 3rd Gen. Powertrain 17 03-05-2016 09:22 AM
No gears- moves in park Cumminspastya 3rd Gen. Powertrain 10 07-27-2015 08:58 PM
Truck Stuck In Park? 08QuadCTD 2013-2018 General Discussion 16 02-07-2015 10:39 PM
