Leak ? - Dodge Cummins Diesel Forum
post #1 of 7 (permalink) Old 04-15-2019, 06:18 PM Thread Starter
murph4w's Avatar
Leak ?
Dumb question but the tappet cover should only leak oil right?
01' QC,4wd,Georend w/Billet input,triple disk,S&B,4" turbo back,Airdog,FS2500,BD manifold,Super B, silicone boots,Comp,Smarty,FBD 150's,Gauges,AGM batteries,Billsteins,DDM 6000K,Sport headlight conv.,Amsoil everything.
murph4w is online now
post #2 of 7 (permalink) Old 04-15-2019, 07:28 PM
Clunk's Avatar
Yup, yours leaking something else?
'01.5 QC, SB, 6spd 4x4, Drag Comp, 4" exh. Jammer 100's, 62-65-.70A/R WG, adj.boost elbow Big Line, fuel press.pyro & boost gauges fuel cooler BHAF, Black Holley lift pump-12psi WOT Ceramic/Kevlar SD clutch, studs Take time to turn-so you don't burn
Clunk is offline
post #3 of 7 (permalink) Old 04-15-2019, 09:15 PM
Yes, what are you leaking? Oil, trani fluid, PS fluid, fuel, coolant? Where exactly?
bigfish95971 is offline
post #4 of 7 (permalink) Old 04-20-2019, 01:55 AM
Yup, what is it leaking?
mtprice93 is offline
post #5 of 7 (permalink) Old 04-20-2019, 02:45 PM
agreed....
98.5 | QCLB | 47RE | 4x4 | ARP | BD | DAP | FASS | Fleece | Fluidamper | iQuad | S&B | 4" Straight pipe
53 block madness is offline
post #6 of 7 (permalink) Old 04-20-2019, 04:20 PM
NCC74656's Avatar
you should have less than 1 quart per month of washer fluid leaking out of that
99 QC,LB. full billet trans, fass 150, iquad, 37", 407Lbs grill guard, DAP VP44, Thuren coils, Thuren king shocks, DoR control arms and trackbar, 16K lbs winch, retro solutions HID. Redhead gear box, compound turbo, DAP 125's, stroker W/HO pistons, 4.10/Elocker
NCC74656 is offline
post #7 of 7 (permalink) Old 04-20-2019, 08:05 PM
Killjoy's Avatar
You got that right. I lost a whole gallon of washer fluid in three days due to a severe leak. It was even the expensive bug wash kind....
2002 ram 2500 quad cab shortbed ST. Red, 4x4, nv4500 swap 24v, 66mm silver bullet, 100hp injectors , fass titanium 150, 4" exhaust, guages. 190k miles.
Killjoy is offline
Similar Threads
Ok to Idle 5.9 Cummins Without Damper? to Troubleshoot Oil Leak JenDodge 94-98 Powertrain 35 02-16-2017 12:33 PM
NV5600 Oil Leak, Any Other Ideas? krashDH 3rd Gen. Powertrain 0 11-04-2016 04:16 PM
Another oil leak... wheeltrax 98.5-02 Powertrain 8 03-30-2016 04:06 PM
Lucas Fuel Treatment and Fuel Leak atmechanical 94-98 Powertrain 4 05-03-2012 11:00 AM
Joe G's fuel system writeup ykdave 94-98 Engine 2 04-22-2008 09:13 AM
