Dana 70 Diff Mess - Page 2 - Dodge Cummins Diesel Forum
 1Likes
post #13 of 17 (permalink) Old 04-16-2019, 01:53 PM
KATOOM's Avatar
I second the rebuild. Then you know its good and you have something that should last without the unknowns of its prior history. And the axle ratio will be on the metal tag or on the build code sticker which may still be on the inside of the glovebox.
KATOOM is offline
post #14 of 17 (permalink) Old 04-16-2019, 02:24 PM
NCC74656's Avatar
in the metro here there are many shops and good people on craigs list too if you dont know how to do it your self. if you need a good gear mechanic out of his garage i know some numbers. just pm me and ill reach out to them if you choose to go that way
99 QC,LB. full billet trans, fass 150, iquad, 37", 407Lbs grill guard, DAP VP44, Thuren coils, Thuren king shocks, DoR control arms and trackbar, 16K lbs winch, retro solutions HID. Redhead gear box, compound turbo, DAP 125's, stroker W/HO pistons, 4.10/Elocker
NCC74656 is online now
post #15 of 17 (permalink) Old 04-16-2019, 02:41 PM
Killjoy's Avatar
Spin your yoke. If you spin 3.5~ times for the axle to make one complete revolution, its 3 55...
2002 ram 2500 quad cab shortbed ST. Red, 4x4, nv4500 swap 24v, 66mm silver bullet, 100hp injectors , fass titanium 150, 4" exhaust, guages. 190k miles.
Killjoy is offline
post #16 of 17 (permalink) Old 04-17-2019, 08:06 PM Thread Starter
Citori13's Avatar
Alright, so I decided I want to do a rebuild so that I don't risk swapping axles and running into problems again. I think I am going to try and tackle it myself to save some money. I have never done gears before but I know I can figure it out if I take my time and get the right tools. I am going to see if I can tear into it this weekend to pull everything out and asses what needs to be replaced. I also think I am going to do a full rebuild on all the bearings and seals while I am in there.
As for parts, it appears there is a proven force store within 15 minutes of my house so I may try them. Otherwise is the randy's pinion and gears website randysworldwide.com? I google searched them and a few different ones popped up.
What brand gears would you guys recommend? I know I see a lot of people using Yukons. I guess it will depend on what all I will need to replace once I get into it but I know for sure the spiders need to be replaced. As for bearings I know Timken have a good reputation are there any others?
2001 2500 4x4 quad cab, Industrial Injection phat shaft turbo, Ind Inj 150 HP injectors, Air dog 100, 5" Turbo back exhaust, Quadzilla Tuner with Pod Controls, 47re rebuilt automatic trans with billet input, mid, and output shafts
Citori13 is offline
post #17 of 17 (permalink) Old 04-17-2019, 09:15 PM
NCC74656's Avatar
timkin are good. i use USgears for my bearings and YUKON for my R and P. ive been using them since building rock crawlers with my auto teacher in HS. youkons can be noiser but they are strong as frigg and in our trucks noise is not an issue
Similar Threads
Looking for a shop in the Amarillo area to rebuild a Dana 70 diff psytechguy Texas 0 02-29-2016 08:28 AM
Dana 70 rear diff fluid amounts with magh-hytec cover and friction modifier? cummins11290 98.5-02 Powertrain 1 06-16-2014 06:45 PM
Wonder what is the hybrid Dana 80? Read this thread. KATOOM 98.5-02 Powertrain 9 06-22-2013 03:33 PM
Dana 70, Dana 80, and tru track limited slip for sale!! ja564rm80 New York 0 09-01-2012 12:39 PM
Dana 80 diff cover anything else I should do while I'm here justblazespcummins 98.5-02 Non-Powertrain 3 08-25-2012 12:42 PM
