Need to hook up a second fuel pressure gauge - Dodge Cummins Diesel Forum
post #1 of 13 (permalink) Old 07-20-2014, 11:35 PM Thread Starter
TB612's Avatar
My Fuel pressure was 6 this afternoon when I went out to my truck, Fass comes on, sounds normal, took off return line, its pumping a healthy amount of fuel seemingly (to the eye), but gauge isn't reading that I have good pressure, second time I turned the key it only read 2 psi.
My question is how do I hook up a gauge under hood and what type of gauge do I need? I have the fuel line T'd off the main line from the Fass to the VP.
Thanks in advance
2001 2500 qcsb, NV4500, 4in. turbo-back, BHAF, Edge Comp, FASS150 with sump, Isspros, BorgWarner 63/68/.80 t3 gated with DFI 7x.011, Valair ceramic dual disk
TB612 is offline
post #2 of 13 (permalink) Old 07-20-2014, 11:45 PM
WillM's Avatar
iTrader Score: 12 reviews
What type of gauge are you using now?
"I didn't choose the '91.5z lyfe; the '91.5z lyfe chose me."
-Texasz Bilitz
WillM is offline
post #3 of 13 (permalink) Old 07-20-2014, 11:54 PM Thread Starter
TB612's Avatar
ISSPRO mechanical gauge and I am using an isolator to keep the diesel out the cab
TB612 is offline
post #4 of 13 (permalink) Old 07-21-2014, 12:00 AM
WillM's Avatar
Sounds to me like the isolator might be your problem.
Either go to an auto parts store and get a fuel pressure test kit, and thread that into the 1/8" port on your tee, or just remove your isolator and directly plumb your ISSPRO.
-Texasz Bilitz
WillM is offline
post #5 of 13 (permalink) Old 07-21-2014, 12:04 AM Thread Starter
TB612's Avatar
I will mess with the isolator once I get a pressure test kit on it to diagnose that it isn't a problem to drive. I am currently 300 miles from home at my parents.
The isolator is so simple (just a diaphram between diesel fuel, and coolant to the gauge) the only thing that could go wrong in my mind is the diaphram rupturing, which would simply allow diesel fuel to leak through, but that would still create pressure against the gauge port I think. unless the diaphram ruptured and then clogged the port at the back side of the gauge
TB612 is offline
post #6 of 13 (permalink) Old 07-21-2014, 05:35 AM
You can screw a 20 dollar manual gauge into the top of the fuel filter housing and check it against your gauge without messing with anything.
bigfish95971 is offline
post #7 of 13 (permalink) Old 07-21-2014, 09:40 AM
WillM's Avatar
He doesn't have a stock fuel filter housing.
-Texasz Bilitz
WillM is offline
post #8 of 13 (permalink) Old 07-21-2014, 04:34 PM
I take it you are saying the aftermarket ones do not nave a 1/8 in pipe tread port in them? Guess he is screwed then. He will have to make a fitting fit somewhere.
post #9 of 13 (permalink) Old 07-21-2014, 04:43 PM
Check at the back of the gauge to see if the line is full. People have had issues with losing the antifreeze & getting bad readings.
Ed
2001 2WD SCLB (ex fleet truck) 237,000 stock rebuild on 47RE, BHAF, 4" w/ muffler w/ turndown, Quad Adrenaline with pod, FRRP, 3.55
Yankneck696 is offline
The Following User Says Thank You to Yankneck696 For This Useful Post:
Cleftwynd (07-22-2014)
post #10 of 13 (permalink) Old 07-21-2014, 06:19 PM
Spravecek's Avatar
You know I have the same set up and could smell diesel fuel in my coolant side of the issolator
Might just go to a straight line and delete the issolator. Too many brass fittings anyways!
2001 Cummins auto 24v --2013 jetta TDI- Bilstein5100
Edge Hot-AFe intake - DFI 7x.09 Fass titanium-3.55gear
-Isspro EV2 Boost and FP 305/75/16 nitto grapplers
Spravecek is offline
post #11 of 13 (permalink) Old 07-21-2014, 11:13 PM
WillM's Avatar
Thanks in advance
____________________
-Texasz Bilitz
WillM is offline
post #12 of 13 (permalink) Old 07-21-2014, 11:29 PM
CumminsCowboyNE's Avatar
you would need a tapped banjo bolt that replaces the factory inlet banjo bolt at the vp and just plumb a mechanical gauge off that. as far as a gauge goes. 30 psi gauges is all you need. we use the liquid filled gauges.
Get off my lawn.
CumminsCowboyNE is offline
