Dana 70 Rear Maintenance - Dodge Cummins Diesel Forum
post #1 of 12 (permalink) Old 07-19-2014, 07:16 PM Thread Starter
Diesel_River's Avatar
So my rear end is gonna get some work done. Im planning on putting in some 75W-140 Syntheic Royal Purple oil (How much does it take?), It's limited slip so im guessing i need friction modifier? (How much do i need and how do i add it?), and a new gasket for the cover. Anything else i should do while im in there? Things to look for? The reason i'm doing work on it is because the rear end seems to kind of "catch" mainly while reversing slowly and/or turning slowly, sound like the diff oil? Or maybe somebody didn't add friction modifier or did it wrong before? Thanks for the help guys, this is my first time cracking open a differential cover.
River - 1999 QCLB 2500 4x4 "Doge" . Edge Juice CTS with Attitude HOT UNLOCK, 5in Diamond Eye Exhaust with 51in Donaldson muffler and 6in MBRP Tip, Factory HD Steering, FASS OEM Style Lift Pump. 33in BFG KM2 Mud Terrains. Access Tonnosport Cover. 3000 Lumen 6000k LED Headlight Bulbs, Rigid Industries Dually's (Flood Beam)
Diesel_River is offline
post #2 of 12 (permalink) Old 07-19-2014, 07:50 PM
my_samurai's Avatar
Really nothing to changing the fluid. That catch in mine was a broken tooth on a spider inside the limited slip. So good luck inspect it well
98.5 2500 QC LB,BHAF, Edge Juice Hot/Smarty,meth,DFI 7x.011, AD150, FMW62/68/14,ARP, Revmax Signature Series ,Metalcloak Arms, Thuren coils, 5100's
91 W250 FLATBED 6" lift , tuned pump, HX35 Revmax Converter
my_samurai is offline
post #3 of 12 (permalink) Old 07-19-2014, 08:02 PM
D70
According to my 2002 factory service manual the D70 rear axle gets 3.1 L (6.5 pts) for the 2wd & 3.4L (7.2 pts) for 4wd with 7oz/8oz respectively of friction modifier. No gasket used on the turkey pan cover, just clean thoroughly and rtv it. Confirm the amounts match your specific application. Hope this helps
2002 3500 6 Sp QCab4X, 3/10 micron fuel filters, Airdog, -6 fuel lines, full gauge pkg, Quad Adrenaline V2, SB 1947-OK-HD Clutch, PacBrake, 4" Exhaust, 3rd Gen Brakes, RV275's, ARP Studs, Borg Box, 4th Gen Steering, Mr Bob Hoses, Walker Air Sep CC Vent, 80K Miles.
ram350002 is offline
post #4 of 12 (permalink) Old 07-19-2014, 08:19 PM
95dodgev10's Avatar
Royal purple already has friction modifier in it so no need for extra
3" spring spacers,method race wheels,general grabber 315 75 r16, edge prog. New vp so no wire tap yet,100hp injectors,4" straight pipe, and a few other things
95dodgev10 is offline
post #5 of 12 (permalink) Old 07-19-2014, 08:25 PM Thread Starter
I found a gasket online though, wouldn't that be better then just using rtv?
post #6 of 12 (permalink) Old 07-19-2014, 09:45 PM
Gasket
I guess it just depends on much you enjoy scraping old rtv off, either should seal fine assuming the gasket is the correct materail. I have a Mag-Hytec cover with an o-ring seal, 1 extra qt of oil and a drain plug which eliminated all these issues.
post #7 of 12 (permalink) Old 07-21-2014, 06:06 AM
Look for metal in the bottom of housing. Look for play in pinions or roughness in carrier bearings. If you have something rough or "catching" You probably need rebuild. Plus check your u-joints.
bigfish95971 is offline
post #8 of 12 (permalink) Old 07-21-2014, 06:12 PM
Spravecek's Avatar
Took off my pan drained the oil and I used normal black rtv. Don't have to get crazy just spread it evenly
Be careful tho that rear end oil stinks like all hell try not to spill any! Learned the hard way.
2001 Cummins auto 24v --2013 jetta TDI- Bilstein5100
Edge Hot-AFe intake - DFI 7x.09 Fass titanium-3.55gear
-Isspro EV2 Boost and FP 305/75/16 nitto grapplers
Spravecek is offline
post #9 of 12 (permalink) Old 07-22-2014, 12:25 AM
Automotive Connoisseur
seanb02's Avatar
No. Factory uses RTV type sealant rather than a gasket. This is because the metal is so thin, it very rarely has a perfectly even sealing surface. The RTV fills in the slightly different levels and creates a good sealing surface, whereas a gasket is a uniform thickness and cant compensate to the same extent for a sealing surface that isn't perfectly uniform. Clean both sealing surfaces well removing all the old RTV, and apply about a 1/8" bead of new RTV on the cover and reinstall torquing the bolts in the correct pattern.
2002 6 SPEED QCSB 4x4
- 2005 GMC 2500HD Duramax -
- 2018 Nash 26N TT -
- 1968 Thunderbird 429 Landau -
seanb02 is offline
post #10 of 12 (permalink) Old 07-22-2014, 12:29 AM
You can buy the gasket at any parts store.
post #11 of 12 (permalink) Old 07-22-2014, 12:30 AM
seanb02's Avatar
Stinks? I actually don't mind the smell of most oil. Also I forgot and left a coffee can under a leaking differential in a 1945 Ford pickup once for nearly a year. By the time I retrieved the can, it was half full of oil and had about 10-20 snails and frogs drowned in it. Must smell good to them.
seanb02 is offline
post #12 of 12 (permalink) Old 07-22-2014, 12:34 AM
seanb02's Avatar
Yes, but as I just mentioned, from my own experience using both types with different vehicles, the gasket is more trouble than not. Since most manufactures use RTV type sealant from the factory on these differentials, there must be some science to it. It is cheap and easy enough to use if you are careful, but if not it can get messy.
seanb02 is offline
