Adrenaline vs adrenaline 4k board differences - Dodge Cummins Diesel Forum
post #1 of 102 (permalink) Old 05-22-2013, 01:41 PM Thread Starter
me78569's Avatar
I myself am not interested in upgrading my box to a 4k, but I know a lot of guys are. So I went out to the truck and pulled my box out and took it apart. Simple to do. There are 2 screws on the face of the unit that once out allow you to remove the board. I snapped a few pictures of the board. Keep in mind that this is a 98.5-00 adrenline. I would be interested to see some 01 and 02 boxes also, regardless of the 4k or standard.
Looking over it there are a few things that stick out as something that could be changed in order to allow for the 4k upgrade. I found a post from 2010 from quadzilla stating that the box needed a simple change internally that took less than a minute. I would assume , if this is the true, that this means that the change has to be pretty simple to do. Jason verified this in a thread recently about changing to 4k. He however stated that he has no interest in doing this for people so please don't bother him about it. We can't blame him for not wanting to pickup where quad left us hanging.
Here is the full front face of the board
Here is the full rear face ( mirror it in your mind to see the front vs back lineup of parts)
Here is the left side of the board. You have the 2x10 chip space empty and a jumper. Does anyone know what the jumper does? I have read that people reported removing the jumper for more accurate boost readings? https://www.cumminsforum.com/forum/98...or-issues.html
Here is another thread to confirm this jumper has to do with boost and differences between year trucks.
https://www.cumminsforum.com/forum/98...ml#post5389855
Here is the right side of the board showing the 2 things that I see as easy to replace. I believe that they are resitors, but I am not very good with techincal names. What I see however is the ability to easily solder a different part into place of it.
Here is the back as you can see there are only 4 items that I see as easily change able. Everything else is soldered into the middle boards of the main board. Two "resistors"? ( not up to snuff on technical names), a jumper, and an empty socket for a 2x10 chip
I figured that if we could get a picture or two of a 4k box internally that we might be able to spot the difference. Is anyone with a 4k box willing do take it apart and snap some pictures? It would be nice to put to rest the questions about going to 4k boxes and hopefully keep people from loading a 4k tune onto a regular box. Does anyone have any first hand knowledge of the "change" that needs to be made?
2018 3500 CCLB G56
me78569 is offline
post #2 of 102 (permalink) Old 05-27-2013, 07:21 PM Thread Starter
me78569's Avatar
Bump,
No one with a 4k box is willing to take a couple pictures?
Am I way off base here?
2018 3500 CCLB G56
me78569 is offline
post #3 of 102 (permalink) Old 05-27-2013, 07:51 PM
irish power mad's Avatar
Interesting.
Am I the only one who knows everything?
01 3500 Dually Q.CAB, Quad Adr.,pulse, 4" straight stainless exhaust, air dog FP 150 fuel preporator,
half inch draw straw and fuel lines.Rancho 5000 shocks rear, 9 way adjustable up front, 3.55 rear end.DIY built DTT trans, triple disc low stall Goerand tc,billet flex plate and input shaft, DTT shift kit, Holset HX40W 60/65/16 turbo(stock turbo propping the door open
)125hp DAP injectors pushing on the pistons, BHAF and more to come
irish power mad is offline
post #4 of 102 (permalink) Old 05-27-2013, 11:11 PM Thread Starter
me78569's Avatar
Yea I really wish we could get some pictures of a 4k board so we could see if there are differences or if the update is a firmware update etc etc? It seems like multiple times a week this question comes up so it would be nice to have some proof instead of people saying this or that according to a friend etc etc.
2018 3500 CCLB G56
me78569 is offline
The Following User Says Thank You to me78569 For This Useful Post:
jmd025 (05-28-2013)
post #5 of 102 (permalink) Old 05-27-2013, 11:36 PM
NCC74656's Avatar
so to run a 4K tune you need to modify the hardware? i thought you just had to flash the programming...
99 QC,LB. full billet trans, fass 150, iquad, 37", 407Lbs grill guard, DAP VP44, Thuren coils, Thuren king shocks, DoR control arms and trackbar, 16K lbs winch, retro solutions HID. Redhead gear box, compound turbo, DAP 125's, stroker W/HO pistons, 4.10/Elocker
NCC74656 is offline
post #6 of 102 (permalink) Old 05-27-2013, 11:48 PM
Wyoming Eastern President
razocow's Avatar
I never bought into the need to change hardware, the beta 4k tune worked great on my quad
2000 quad cab short bed= Grandpa truck
S475 single, 7x23 dual feed injectors, fass 200, built auto, studded, two stage nitrous, Quad, Tial= SOLD
2007.5 QCSB Inferno Red= Dorthy
Fully Deleted, H&S Mini Max with OD, AFE intake, 5" straight pipe, H&S rail plug, FS2500 Bypass
-I rep for the AARP crowd-
razocow is offline
post #7 of 102 (permalink) Old 05-27-2013, 11:56 PM Thread Starter
me78569's Avatar
Are you able to rev past 3200 rpm now? You just loaded a 4k tune onto the unit? I have heard horror stories about doing this and having a useless box. Again I heard this and can't actually say firsthand. Can you post images of your box? your custom tuning page?
This is where the issues come up. Quad had said in the past (take it for what you want) that there was an internal change that had to be made that took around a minute to do.
I don't doubt that there needs to be a firmware update to happen in order to go from reg to 4k but I am not sure about the hardware. That is the reason for this thread. if we could get internal pictures of a original 4k we could know for sure if there were internal changes made or not.
2018 3500 CCLB G56
me78569 is offline
post #8 of 102 (permalink) Old 05-28-2013, 05:35 PM
kendrickDan's Avatar
subscribed. I would take pics if i had a 4k box. If it were just a update then I think you wouldn't have to send it in. I think u are on track.
2000 with 01 motor, 250hp injects, hx40w/billet wheel, fass lift pump, edge comp, fluid dampner, dual disk clutch
kendrickDan is offline
post #9 of 102 (permalink) Old 05-28-2013, 06:09 PM
Mule Barn Proprietor
jmd025's Avatar
iTrader Score: 9 reviews
I like this thread. Sorry no adrenalines to show you but I definitely buy in to what you are doing here!
Sent from my Saxaphone
This Machine Thrills Fascists
No more Cummings
jmd025 is offline
post #10 of 102 (permalink) Old 05-28-2013, 06:31 PM
SuperISBee's Avatar
"Better to remain silent and be thought a fool than to speak out and remove all doubt"
SuperISBee is offline
post #11 of 102 (permalink) Old 05-28-2013, 06:46 PM
SuperISBee's Avatar
Originally Posted by me78569 View Post
Bump,
I don't think your off base at all.
I was on the fence about trying quad/adrenaline right around the time they went MIA. Still running Edge Comp "HOT"...
Anyway, the main reason for my response is...
It's nice to read a thread that was well thought out, articulated well with clear photos.
Prospective poster's should take note and follow suit!
The Following User Says Thank You to SuperISBee For This Useful Post:
Yankneck696 (05-28-2013)
post #12 of 102 (permalink) Old 05-28-2013, 07:11 PM Thread Starter
me78569's Avatar
Many years on forums here and there have taught me how to make a thread that is worth the time to read.
Thanks again guys. I might have to resort to pm'ing guys with the 4k box and see if they can't take a couple minutes to pull it apart and snap a few pictures.
I have a hard time believing that Quadzilla would have a circuit board made that had that 2x10 chip in it without reason for it. It would be nice to know what the hardware differences are between the years and model of the adrenaline.
2018 3500 CCLB G56
me78569 is offline
