Timing issue with quadzilla - Dodge Cummins Diesel Forum
post #1 of 12 (permalink) Old 01-25-2020, 03:54 PM Thread Starter
Voltronics's Avatar
I’ve had this problem for 3 months now when I decelerate my truck makes a knocking noise from 1800-1200 rpm the timing is at 19* there to about 18* the fuel tap when I decelerate is 0 On the quad and I can’t figure out if this is causing the knock or not.
58/65/14 turbo, 5in exhaust, 150dap injectors, quadzilla, hot rod vp44, sb cold air Intake, bd exhaust manifold, big ram Intake manifold, head studs, dual disk clutch, fass 165
Voltronics is offline
post #2 of 12 (permalink) Old 01-25-2020, 03:57 PM Thread Starter
Voltronics's Avatar
These are my timing and rpm settings on my quad
ID:	865879   Click image for larger version
post #3 of 12 (permalink) Old 01-25-2020, 04:12 PM
me78569's Avatar
When you decel are you on the throttle?
2018 3500 CCLB G56
me78569 is offline
post #4 of 12 (permalink) Old 01-25-2020, 06:28 PM Thread Starter
Voltronics's Avatar
no not at all or like if I’m coming onto a car slowly and I have to let off the throttle around those rpms it will make the noise almost like knocking
post #5 of 12 (permalink) Old 01-25-2020, 10:46 PM
me78569's Avatar
No throttle means the quad isnt altering fueling and timing.
me78569 is offline
post #6 of 12 (permalink) Old 01-25-2020, 11:30 PM Thread Starter
Voltronics's Avatar
so when I am around those rpm and are decelerating with no throttle the timing isn’t at 19*? Becusse my truck seems to make the noise in that rpm range when there is no throttle so could it be fuel knock or?
post #7 of 12 (permalink) Old 01-25-2020, 11:34 PM
me78569's Avatar
The quad will display the current timing to the pump,
but if TPS = 0% then the quadzilla is not sending fueling and timing messages. At 0% tps the fueling and timing commands are %100 oem commands.
It might be knock, but it has nothing to do with the quad.
2018 3500 CCLB G56
me78569 is offline
post #8 of 12 (permalink) Old 01-25-2020, 11:35 PM Thread Starter
Voltronics's Avatar
This is the noise I’m referring to
https://youtu.be/FCQ8JmKGIyE
Already changed the injectors to brand new dap 150s and the problem still persists
post #9 of 12 (permalink) Old 01-25-2020, 11:36 PM Thread Starter
Voltronics's Avatar
I’m new to these engines, I’m assuming that knock is bad when it comes the diesels like on gas vehicles. The truck builds boost all the way up to 40psi and the oil pressure hasn’t moved at all. Would knock cause any of this to not be true ?
post #10 of 12 (permalink) Old 01-26-2020, 12:43 AM
me78569's Avatar
I wouldnt worry about knock personally.
me78569 is offline
post #11 of 12 (permalink) Old 01-26-2020, 01:49 AM
Originally Posted by Voltronics View Post
Iíve had this problem for 3 months now when I decelerate my truck makes a knocking noise from 1800-1200 rpm the timing is at 19* there to about 18* the fuel tap when I decelerate is 0 On the quad and I canít figure out if this is causing the knock or not.
Unplug the quadzilla see if it goes away or changes the knock,wouldnt be the first time a aftermarket part caused bizzare issues.i had a smarty cause my torque converter to hunt for lock up just by it being plugged in the obd port.
ArNy32 is offline
post #12 of 12 (permalink) Old 02-10-2020, 09:16 PM Thread Starter
Voltronics's Avatar
It’s still there with the quadzilla but more pronounced
