01 cummins plenty of fuel, plenty of air won't pass 33psi. Help - Dodge Cummins Diesel Forum
 4Likes
  • 1 Post By me78569
  • 1 Post By WillM
  • 1 Post By me78569
  • 1 Post By me78569
post #1 of 11 (permalink) Old 09-20-2019, 10:38 PM Thread Starter
I have 2001 Dodge cummins with few good mods. 150 airdog, air intake, edge juice with attitude hot unlock, 5" turbo back straight pipe exhaust, air ram intake. With stock turbo was pushing 35 to 36 psi. Fantastic. Later, decided to upgrade turbo to a fleece cheetah which is a 63mm turbo which was supposed to increase boost significantly. Installed it with high expectations, but was greatly disappointed. At this moment, turbo doesn't pass 33psi. I did everything I can think of. Maxed out wastegate, put boost elbow with pin hole, modified other boost elbow drilled hole and put screw in, totally bypassing wastegate with no improvements. I can't pass 33 pounds of boost. What can I do?
Jmorillo is offline
post #2 of 11 (permalink) Old 09-20-2019, 10:45 PM
chadmac's Avatar
First thing I would check is for a boost leak...especially after just cracking open that piping and suddenly having a boost issue.
02 2500 4X4, reg cab shorty, 3.55, Smarty/TST, 75 over 62, 150 inj, 5" exh, 12" lift on 20" 34's, Goerend billet triple disc auto, Yukon hub/bearing kit
chadmac is offline
post #3 of 11 (permalink) Old 09-20-2019, 11:18 PM
me78569's Avatar
I dont see any injectors in your list?
If you are still running stock injectors then I wouldn't expect any more boost.
You are signficantly under fueled if you are still running stock injectors.
Clunk likes this.
2018 3500 CCLB G56
me78569 is offline
post #4 of 11 (permalink) Old 09-21-2019, 12:51 AM
WillM's Avatar
iTrader Score: 10 reviews
Fell for the online deezul rackets.
You can't make more boost without more fuel. I'd order a set of 7x.010" injectors, and in the mean time pressurize the system and check for boost leaks, just because that's good preventative maintenance.
Clunk likes this.
"I didn't choose the '91.5z lyfe; the '91.5z lyfe chose me."
-Texasz Bilitz
WillM is offline
post #5 of 11 (permalink) Old 09-21-2019, 08:12 AM Thread Starter
I don't think I have a boost leak but I'll check it out. What I don't understand is that I made more boost with stock turbo. I was gonna get injectors but wanted to ask first before spending more money and hope it fixes it. Im also getting new boots.
Jmorillo is offline
post #6 of 11 (permalink) Old 09-21-2019, 11:57 AM
me78569's Avatar
The stock turbo is smaller, it takes less fuel to spin.
A bigger turbo will make less boost unless you asdd fuel.
Also boost and cfm are different. A biggr turbo will flow more cfm of air at a given psi than a smaller turbo.
Clunk likes this.
me78569 is offline
post #7 of 11 (permalink) Old 09-21-2019, 04:44 PM Thread Starter
Ok. Injectors it is. Which injectors would y'all recommend to reach upwards of 40psi?
Jmorillo is offline
post #8 of 11 (permalink) Old 09-21-2019, 06:04 PM
me78569's Avatar
Why are you stuck on psi? Create power goals, psi is not important.
Generally 7 x .010's are the most widely used vp injector on a street driven truck.
Clunk likes this.
me78569 is offline
post #9 of 11 (permalink) Old 09-21-2019, 08:13 PM Thread Starter
I word it wrong. Which injectors is recommended for this specific turbo to perform it's best. I'm not gonna do much more to this truck. I just want everything that I've done to it be performing as they should. Big power gains are not on my mind at the moment. In the future I might run a different setup.
Jmorillo is offline
post #10 of 11 (permalink) Old 09-22-2019, 09:34 PM
Clunk's Avatar
Either go to a dyno or a good straight Test Hill to try yer stuff,
'01.5 QC, SB, 6spd 4x4, Drag Comp, 4" exh. Jammer 100's, 62-65-.70A/R WG, adj.boost elbow Big Line, fuel press.pyro & boost gauges fuel cooler BHAF, Black Holley lift pump-12psi WOT Ceramic/Kevlar SD clutch, studs Take time to turn-so you don't burn
Clunk is offline
post #11 of 11 (permalink) Old 09-28-2019, 12:11 AM
Monstermaker's Avatar
That turbo is probably flowing more air at 30 PSI than your stock one did at 35 PSI.
The stock one is making more heat than actual flow past about 32 or so.
'99 QC 4x4 Dually.
In the near future Iím ripping out all the electronic junk and P-pumping it.
Built trans, Gear Vendors overdrive, Kelderman Air Ride
Monstermaker is offline
