Fass filter, which elements to use? - Dodge Cummins Diesel Forum
post #1 of 9 (permalink) Old 08-14-2019, 12:10 AM Thread Starter
My 02 has the FASS fuel pump. I am going to replace the FASS-brand filters, it has two, I believe theres a particulate filter and a water-separator.
The local Dodge/Cummins parts-selling guy says the Fass Filters are not particularly good quality, and that I should use the Fleetrite brand - which he happens to sell - because they are good quality filters.
In my experience, any store with a filter on the shelf will claim their filter is a good quality filter.
My questions is, what brand / filter-number do all the other guys who run the FASS pump use?
Is there a particular brand NOT to use?
And what is the change interval on the filter elements?
Thanks, Jiggseob
jiggseob is offline
post #2 of 9 (permalink) Old 08-14-2019, 05:25 AM
ledjunkie's Avatar
You need to find out what Fass System you have by looking at the tag. I have an older Fass 150 and the water separation filter was the FS 1001, the 3um Fuel filter is FASS FF-1003. I have FleetGuard filters on my system. The problem I had was the thread housing was the large threading nearly the same diameter of the filter. The newer systems have the smaller inlet so buying blind was an issue. It took looking up the model # of the FASS to determine what filter would fit since my old filter was so old the filter number was difficult to read.
There are a ton of filters that cross reference that will fit in varying degrees of filtration levels and you will need to check. I had a very large list somewhere...Baldwin makes some, Napa branded which are Wix I think.
Fleetguard FS1023
Donaldson P550828
Cim-Tek 70804
Fuel Preporator FP804
Fuel Preporator FP8041
Fuel Preporator WS200
Here is a better thread
And Another for the FASS 150
2001 Dodge 2500 5.9, 24v, NV5600, Valair Duel Disc Organic, HX35, Quadzilla Adrenaline, Fass 150, 4" Spacer, 1"Block, 5100s, Steering Brace, Rare Parts Track Bar, Cooper AT3s 315/75/16, Pro Comp Extreme wheels, Tough Country Step Bars.
ledjunkie is offline
The Following User Says Thank You to ledjunkie For This Useful Post:
Clunk (08-14-2019)
post #3 of 9 (permalink) Old 08-14-2019, 11:18 PM
buy from fass and no one else
smokestack69 is offline
post #4 of 9 (permalink) Old 08-15-2019, 02:04 AM Thread Starter
I rubbed the road-crud off the fass-pump, I find no reference to the model number differentiating 95 or 165 or 250 or 290 gph. I did find the decal with Fass Titanium signature series and a serial number. Is there any way to tell the gph rating, or does it matter once I find the thread-size of the filter bases?
I did find that the water separator is a Baldwin BF1212, which the Baldwin catalog says is a 1-14 thread. The fuel filter is a WIX brand with the numbers rubbed off.
I see micron ratings from 2 through 10 microns on fuel filters. I presume the smaller micron rating means cleaner fuel...??
I will take them off and take them to my Fass dealer to cross them up.
I have always regarded Baldwin filters as being top quality, so if my local Baldwin dealer has what I need, I think I will get them from him.
jiggseob is offline
post #5 of 9 (permalink) Old 08-15-2019, 10:35 AM
ledjunkie's Avatar
Yes, The lower the number the higher level of filtration.
The Titanium Series may or may not need an adapter depending on age. The older models have Red or Blue bases
FASS Filters
NOTE: Titanium Filter Conversion
FF-2003 ( ORDER FWS 3003 and Adapter FSN-2001 )
FF-2010 ( ORDER FWS 3003 and Adapter FSN-2001 )
WS-1001 Pump Base is BLACK ( ORDER FS-1001 )
WS-2001 Pump Base is RED or BLUE ( ORDER FS-2001 )
NOTE: Older Titanium Pump 95/95-1007 and 95/95-1008
Now use Filters FS-2001 and FWS-3003 and FSN-2001 Adapter.
Newer Black based model use different filters. (see link above)
post #6 of 9 (permalink) Old 09-03-2019, 12:50 AM Thread Starter
Wix 33528 2 micron particle filter and Wix 33522 10 micron water filter
Turns out my neighbor who borrows my Kubota tractor works at UAP-NAPA.
He got me a 33528 2 micron particulate filter and a 33522 10 micron water separator. Total cost $28.
Local FASS dealer was giving me a "deal", both filters for $120, reg price $140.
put them on, cycled key a couple times to pump some fuel, no stumbling at all on startup.
All fuel filter changes should be this easy... harken back to a 354 perkins in a 750 MF combine ... anything but "no stumbling on startup"...
jiggseob is offline
post #7 of 9 (permalink) Old 09-04-2019, 01:16 AM
ledjunkie's Avatar
Good to know and glad you got what you needed.
post #8 of 9 (permalink) Old 09-07-2019, 05:19 PM
Monstermaker's Avatar
Iím guessing you own some stock...
'99 QC 4x4 Dually.
In the near future Iím ripping out all the electronic junk and P-pumping it.
Built trans, Gear Vendors overdrive, Kelderman Air Ride
Monstermaker is offline
post #9 of 9 (permalink) Old 09-07-2019, 05:40 PM
nope...
