Need less smoke - Page 2 - Dodge Cummins Diesel Forum
 2Likes
post #13 of 40 (permalink) Old 07-26-2019, 11:27 PM
Stormin08's Avatar
more than likely, that is just the injectors them selves...probably a SAC style tip, and a slight haze is noticed.
my 7x.0085 do the same when on the throttle
02 Sport / 47re / 4" MBRP TBE / DAP 75hp sticks/ HX35W / GDP FUEL BOSS / DDRP02 / 3rd gen brakes / 4th gen steering / 2" Thuren / MC ARMS / 5100's /285/75/17
Stormin08 is offline
post #14 of 40 (permalink) Old 07-27-2019, 07:19 PM
bwdt's Avatar
you need V2 tuning on the Adrenalin to control fueling and more. It should be in the menu.
2000, 2500 4X4 LB, Adrenalin 6X11 injectors, 62-68/12 FMW, 4" exhaust, 2012 T steering, Allison transmission, w/271 Transfer case, 19.5 wheels and tires, 3rd gen brakes, DT Radius Arms, Hamilton 188/208 cam, studs, 19.5-1 pistons, Dana 80, 60 Gal fuel tank, +.
bwdt is offline
post #15 of 40 (permalink) Old 07-27-2019, 08:43 PM Thread Starter
Voltronics's Avatar
I have V2 tuning
Voltronics is offline
post #16 of 40 (permalink) Old 07-28-2019, 09:30 AM
custom user title
thepureface's Avatar
Check for boost leaks? Honestly it doesn’t seem like your setup would be that smokey.
2000 4x4
Built Auto
phatshaft 62 over s475
DOR steering+suspension
P pump swapped
thepureface is offline
post #17 of 40 (permalink) Old 07-28-2019, 10:09 AM
me78569's Avatar
Ddp injectors are smokey. Guy running 150's had more smoke than me running 250's, using the same exact tune. I was even 6000' higher in altitude than him.
Seen this over and over, ddp injectors are bad.
me78569 is offline
post #18 of 40 (permalink) Old 07-28-2019, 04:03 PM Thread Starter
Voltronics's Avatar
After I get some dap injectors would I be fine running the turbo I have now it’s a bd super b single then next summer upgrading to possibly a 62/68/14 turbo?
post #19 of 40 (permalink) Old 07-28-2019, 06:37 PM
me78569's Avatar
it should be fine.
after you get injectors you should have no trouble running smoke free.
2018 3500 CCLB G56
me78569 is offline
post #20 of 40 (permalink) Old 07-28-2019, 06:45 PM Thread Starter
Voltronics's Avatar
it should be fine.
Ok sweet thanks for all the help
post #21 of 40 (permalink) Old 07-29-2019, 07:59 AM
mykeb's Avatar
This is going to sound overly simplified, but....
Can you not clear up the smoke by driving with a lighter touch on the skinny pedal? Ive been driving according to my smoke output since before rollin coal stopped being cool, because ive long since been more interested in efficiency. Biggest i saw was skinny pedal, and adjusting shift points to keep the truck working efficiently as possible.
2001 2500 5spd, 4" straight pipe, fass titanium series, mach1.6 injectors, CAI, adrenaline, southbend dual-friction, 2011 fto wheels
mykeb is offline
post #22 of 40 (permalink) Old 07-29-2019, 08:03 AM
mykeb's Avatar
Not the same setup, but to give you an idea.....i tow a white 10,000lb travel trailer. Have 120h injectors, stock turbo, and the old school pre-EPA quadzilla.
And im not concerned at all about smoke, even when towing thru the mountains. Truck weighs 10k lbs, trailer is 10k, and truck has 3.55gears...so...it knows the trailer is back there
mykeb is offline
post #23 of 40 (permalink) Old 07-29-2019, 08:36 PM Thread Starter
Voltronics's Avatar
I figured out when to shift finally and not have it smoke but now my turbo is not lighting at all I did a wot and got about only 23 psi my egts cruising on flat highway at 70 are at about 700 and boost is at like 3 psi at 70mph I here of guys tuning 20 psi at 70 or even way higher
post #24 of 40 (permalink) Old 07-29-2019, 09:33 PM
me78569's Avatar
again there is no such thing as a "pre-EPA" quadzilla. Quadzilla never had issues with the EPA. Please stop spreading false info.
OP if you can't light the turbo add more fuel in your tune. drop timing a little. you want low psi and egt cruising. That equals good mpg. High psi at cruise = burning a ton of fuel.
runit02 likes this.
2018 3500 CCLB G56
me78569 is offline
