injectors with quad - Dodge Cummins Diesel Forum
post #1 of 17 (permalink) Old 05-21-2019, 10:02 PM Thread Starter
injectors with quad
i am having trouble deciding which injectors to get i have a 2002 so cummins engine block just got back from machine shop 20 over with mahle pistons going in all new bearings and gaskets and fire ringed block. new hamilton 178/208 cam , hamilton tappets, hamilton hd push rods, new cylinder head with valves fire ringed, 6.7 rocker assembly's manton valve bridges. arp 620 head stuts . fire ring head gasket, new industrial injection so vp44, fass 150, steed speed common rail style manifold ( going in ford excursion ) . 4 inch exhaust, quadzilla v2, all aluminum radiator and inter cooler upgrade. fully built ford transmission, re geared to 4.56 gears, lifted 6 inches on 37x17 tires. this will be a daily driver mostly city driving lil towing, its a full ground up restomod new everything. im having trouble deciding on what injectors to get with my setup. i want something fun to drive every day reliable with power . sxe 62/68/12 turbo
adamsquared is offline
post #2 of 17 (permalink) Old 05-21-2019, 10:04 PM
PTSCummins's Avatar
What turbo? 7x.011s or 7x.012s are still plenty cool for a street setup with the right turbo
Sent from my SM-G930W8 using Tapatalk
1999 Ram 2500 QCLB - SO 24V in front of NV4500 and SB DD 3250. Fresh rebuild with ARP studs, CR head, 150HP F1s, Raptor 100, Quadzilla Adrenaline and HX35/S475 (1.10)
PTSCummins is offline
post #3 of 17 (permalink) Old 05-21-2019, 10:08 PM Thread Starter
sxe 62/68/12
post #4 of 17 (permalink) Old 05-21-2019, 10:21 PM
I'm running the same turbo from DAP and they recommended the 7x.010 injectors. Claimed at 150-175 horse injectors. My truck moves out real good thru the whole rpm range. Turbo lights quick and it gooooeeeeesss
Sent from my SM-G973U using Tapatalk
RedrumLx is offline
post #5 of 17 (permalink) Old 05-21-2019, 10:31 PM
me78569's Avatar
7 x.010 as they will give you enough fuel to max that turbo while still being really easy to tune.
me78569 is offline
post #6 of 17 (permalink) Old 05-21-2019, 10:32 PM Thread Starter
how are your egts on those injectors ?. are they sac or vco
post #7 of 17 (permalink) Old 05-21-2019, 10:38 PM
I've never even seen my egt's go above 800. And by the time they even get that high I'm well above the speed limit and have to back off. And they're sac
RedrumLx is offline
post #8 of 17 (permalink) Old 05-21-2019, 10:39 PM
Just cruising mine are always 400-600
RedrumLx is offline
post #9 of 17 (permalink) Old 05-21-2019, 10:46 PM Thread Starter
that's good i was worried about the temps.
post #10 of 17 (permalink) Old 05-21-2019, 11:45 PM
Western WA President
jigabop's Avatar
I'm worried about that gearing...4.56....oof. Even with 37's: 4.56 gearing is gonna be up there in RPM on the freeway in overdrive.
I woulda gone with ~4.10 gearing. get the RPM under 2k @60. You'll have more than enough power to pull longer gearing and make more use of the gearing.
I have 4.10's with 35" tires and I want 3.54 gears with 35" tires... My gearing feels worse than a close ratio 5spd MX bike lol.
00 24v powered by the high performance "53" block and "Unicorn Injectors" 576hp/1285tq 8/10/2013
2004 Jetta TDI 5spd Malone S1 + dyn EGR/idle tune
Originally Posted by DieselDon16 View Post
my truck is literally full of Panties already...
Originally Posted by 'strokeThis_'07 View Post
I'll admit, I was sitting here giggling like a little girl
jigabop is offline
post #11 of 17 (permalink) Old 05-22-2019, 12:05 AM Thread Starter
i was under the assumption that 4.56 gears with 37's netted a close to stock tire size to gear ratio ??
post #12 of 17 (permalink) Old 05-22-2019, 07:08 AM
Stormin08's Avatar
all depends on which....FULLY BUILT FORD TRANS means ?
02 Sport / 47re / 4" MBRP TBE / DAP 75hp sticks/ HX35W / GDP FUEL BOSS / DDRP02 / 3rd gen brakes / 4th gen steering / 2" Thuren / MC ARMS / 5100's /285/75/17
Stormin08 is offline
Similar Threads
II reman ,or Bosch reman updated puck and collar 2000cuminspower 3rd Gen. Powertrain 29 06-20-2014 11:52 PM
Quad with 150 injectors? Texas78 98.5-02 Performance Parts Discussion 8 11-11-2012 09:38 PM
rough idle white smoke... rideorange812 3rd Gen. Powertrain 20 10-13-2011 11:55 PM
