1999 Ram 2500 24v - Dodge Cummins Diesel Forum
post #1 of 13 (permalink) Old 04-24-2019, 12:55 PM Thread Starter
1999 Ram 2500 24v
Bought a 1999 24v cummins over the weekend for $2000. 161,216 miles Kid locked the Transfer case up and messed up the OD where Transfer case attaches. Bought a Transfer case, and OD for transmission waiting on them to arrive, already had the front and rear driveshafts reworked, as well as new u joints and CV joint. Truck starts just fine, and idles smooth. I notice when I step on the pedal a little it shoots up to 2500 rpm very quick, is this normal? Also what are some recommend upgrades for these trucks?
cumminsbro2013 is offline
post #2 of 13 (permalink) Old 04-24-2019, 04:19 PM
NCC74656's Avatar
cv joints? our trucks dont have those.
fass lift pump is my first go to - anything to give you more fuel pressure.
get a fuel pressure gage to monitor things as well.
since you have the trans out you should upgrade your planetary gears as the ones from the factory are VERY weak. replace the torque converter with a tripple disk while your at it, the factory one is also very weak. then you should shift kit the valve body so it flows fluid in park, prevents you running on dry clutch packs.
after that you just need to determine if you are going stock power or adding power. that will determine what other upgrades you should get.
99 QC,LB. full billet trans, fass 150, iquad, 37", 407Lbs grill guard, DAP VP44, Thuren coils, Thuren king shocks, DoR control arms and trackbar, 16K lbs winch, retro solutions HID. Redhead gear box, compound turbo, DAP 125's, stroker W/HO pistons, 4.10/Elocker
NCC74656 is offline
The Following User Says Thank You to NCC74656 For This Useful Post:
cumminsbro2013 (04-25-2019)
post #3 of 13 (permalink) Old 04-24-2019, 06:39 PM
Cummin_get-some's Avatar
Nailed all the basics right there ^^. Just watch a triple disc with a stock input, they like to break. But Trans and Fuel Pressure are big ones here. Once those are covered you have a pretty darn reliable truck. As for other upgrades, how much you wanna spend...
02vp44. 7x0.013's 62/75w Race Cover. 182/214 Hamilton. Quadzilla Water-Meth, Supporting Mods.
Cummin_get-some is offline
post #4 of 13 (permalink) Old 04-24-2019, 06:43 PM Thread Starter
Thanks for the info! Gonna start off slow minus the fuel, and transmission. This is gonna be my workhorse for the farm, plus the occasional fun at the stoplight lol. Already has a hay bed on it. All I need to do is upgrade the transmission for hauling round bales of hay, and trailers, and then whatever you guys suggest under the hood for all of that.
post #5 of 13 (permalink) Old 04-24-2019, 06:44 PM
peanutz's Avatar
i got a tuner new still in box if ya want to juice it up a bit ..... lol
98.5 2500 HD 4X4 all stock but for trans and power puck
peanutz is offline
post #6 of 13 (permalink) Old 04-24-2019, 07:03 PM
NCC74656's Avatar
ive run a stock input for a while with a billet tripple. before i put compounds on but i broke a couple output with out breaking the intputs. now i have billet on 2 and output is an upgraded but not billet - i wanted a fuse.
NCC74656 is offline
post #7 of 13 (permalink) Old 04-24-2019, 07:05 PM
Lol I broke my input when I went compounds too. I tried to leave my output alone but snapped twice trying to launch. So now that's billet too.
post #8 of 13 (permalink) Old 04-24-2019, 07:06 PM
If its just a workhorse id probably just say shift kit and single disc. Then just a edge or a quad. whatever you prefer. I like my quad more.
The Following User Says Thank You to Cummin_get-some For This Useful Post:
post #9 of 13 (permalink) Old 04-24-2019, 07:48 PM
Solid advice^
If you decide you want to grow, there will be more involved with the trans, so it is a good idea to make a end goal before getting into it.
99 Ram 3500 SLT 4x4, 19.5's, P24v, ZF6-750, s362/475, 7x0.014, supporting mods.
marco610 is online now
The Following User Says Thank You to marco610 For This Useful Post:
post #10 of 13 (permalink) Old 04-25-2019, 12:22 PM Thread Starter
What's a good website for pricing and customer service to buy upgrade parts?
post #11 of 13 (permalink) Old 04-25-2019, 01:52 PM
DAP all day long buddy.
post #12 of 13 (permalink) Old 04-25-2019, 02:58 PM
I have the same year truck and everything and since there was good conversation goin I thought I’d ask my question here instead of starting my own thread my truck has been over boosting for awhile and then I changed my map sensor and the truck started to only boost at around 2k rpms and about a week ago it stop boosting altogether for the most part u less I really get in it then it makes about 10lbs I think my wastegate valve in the turbo is stuck what do all of you think.
Ryan Curry is offline
Similar Threads
2009 2500 17in alloys on 1999 2500 hdpwipmonkey 2nd Gen Tire and Wheel 1 07-14-2018 03:08 AM
Front Coil Springs Table luckyhat12 4wd Suspension 21 03-22-2018 11:39 PM
1999 Ctd 2500 rough idle? Tootallscott 98.5-02 Powertrain 12 03-07-2016 07:01 PM
towing with. a 1999 dodge ram 2500 1999dodge5.9 98.5-02 Non-Powertrain 17 10-10-2012 11:53 AM
1999 Dodge 2500 trans problem ironmanjohn25 98.5-02 Powertrain 0 07-24-2011 08:23 PM
