Rear Brake Line Replacement, drop fuel tank? - Dodge Cummins Diesel Forum
post #1 of 8 (permalink) Old 08-06-2012, 08:16 PM Thread Starter
Old_Sparky's Avatar
Question Rear Brake Line Replacement, drop fuel tank?
Now that my power steering is working much better, I have a steel brake line that has decided to get a hole and leak in my garage. I have the line to replace it, but I would like to know if the fuel tank has to be dropped to replace the line, or can you get to all the clips holding the existing line to use on the new line without dropping the fuel tank. Thanks
2000 Dodge RAM 2500, 5.9 Cummins, 4x4, 5-Speed manual transmission. Silverline 4" exhaust, Juice with Attitude, Airdog 100, K&N air filter, 17" rims, big brake upgrade (2004 version), 08.5 steering upgrade, CPP 125 hp injectors.
Old_Sparky is offline
post #2 of 8 (permalink) Old 08-07-2012, 01:22 PM
It would be easier to drop the tank but I did not drop mine when I replaced my rear brake line a few months ago. You can use a longer screwdriver to pry the old line out of the clips and then take it out.
I just used a few pieces of steel brake line to replace mine but if you have a pre-bent one then you might have a lil more trouble working it back between the tank and the frame.
2001 Dodge Ram 2500 2WD Auto 5.9L Cummins: Raptor 150 w/ full 1/2" line kit, DTT Sump, Hypertech 3 Stage programmer, BD Boost Fooler, blocked wastegate, BHAF, 5" RSD exhaust, ISSPRO EGT, boost and fuel pressure gauges.
2001 Hypertech Cummins is offline
post #3 of 8 (permalink) Old 08-07-2012, 05:04 PM
irish power mad's Avatar
It's alot easier to drop the tank, just run it down to 1/8 of fuel and it's light enough to lift by hand.
Am I the only one who knows everything?
01 3500 Dually Q.CAB, Quad Adr.,pulse, 4" straight stainless exhaust, air dog FP 150 fuel preporator,
half inch draw straw and fuel lines.Rancho 5000 shocks rear, 9 way adjustable up front, 3.55 rear end.DIY built DTT trans, triple disc low stall Goerand tc,billet flex plate and input shaft, DTT shift kit, Holset HX40W 60/65/16 turbo(stock turbo propping the door open
)125hp DAP injectors pushing on the pistons, BHAF and more to come
irish power mad is offline
post #4 of 8 (permalink) Old 08-08-2012, 07:11 AM
That's prolly not the best idea if he has a blown brake line. lol
You should be able to carefully use a floor jack to lower the tank if it has much in it.
The Following User Says Thank You to 2001 Hypertech Cummins For This Useful Post:
1BadOilBurnerN-Lv (08-10-2012)
post #5 of 8 (permalink) Old 08-08-2012, 10:49 AM
Mopar1973Man.Com
Mopar1973Man's Avatar
Empty fuel tank is extremely light and yes it can be installed by hand. Done it twice now...
Mopar1973Man is offline
post #6 of 8 (permalink) Old 08-10-2012, 10:34 PM Thread Starter
Old_Sparky's Avatar
We ended up replacing the line without dropping the tank. A friend of mine has done this before, and was very helpful in getting the job done. Thanks for all that have replied.
The Following User Says Thank You to Old_Sparky For This Useful Post:
24hrsparkey (07-12-2014)
post #7 of 8 (permalink) Old 08-10-2012, 10:43 PM
VectorG's Avatar
So glad i live in the South... Good to hear u got it fixed
Names- Tony
Current-01 GMC Ext Cab Long Bed nothing Fancy, 80Hp Edge, Intake, EGR Delete, 5" Exhaust, 6" Lift with 35's, More Mods to come...
VectorG is offline
post #8 of 8 (permalink) Old 08-10-2012, 11:06 PM
Just Another Cummins's Avatar
I was just going to say cut it off and leave what's left in the middle, that's how we do Chevys at work. Then you can just finagle the new line through and clip on either end of the tank.
But since you got it, it doesn't matter. . .
Cameron
01 QC SB 47RE
Tinted WS and all others, Quad ADR, BD150 tips, HX35, Raptor 150-DSV, 4" MBRP,35x13.5-18s
2590.8 MM Western Straight Blade
RU "Sirius"
Just Another Cummins is offline
The Following User Says Thank You to Just Another Cummins For This Useful Post:
