What did you do to your truck today? - Page 1963 - Dodge Cummins Diesel Forum
 483Likes
post #23545 of 23549 (permalink) Old 12-04-2019, 09:01 AM
mopar maniac's Avatar
Hi..its been a while since I've been on... I installed a new stage two trans a week after posting this and its all good now...I hate spending money like that but what you gonna do?
s10010001 likes this.
2001 Dodge 3500 QC Dually 4x4 Auto Trans Edge Attitude w/Juice Banks Monster Ram 100hp injectors 4" MBRP Exhaust Fass 150 PacBrake Exhaust Brake Road Rhino bumpers 12000# winch Vision Crazy Eightz rims 255/85/16 Toyo M/T's ...All my friends bought Harleys...
mopar maniac is offline
post #23546 of 23549 (permalink) Old 12-08-2019, 02:45 PM
krrz350's Avatar
My alternator gauge plummeted when my wife was on the way to our shop. Turns out the water pump bearing let go with no notice, sprayed coolant on the alt causing it to fail. So I did the alt, water pump, belt, and tensioner.
01 388k 2wd dually auto. 5" Straight pipe-TST Comp stacked w/ Flashpaq-Raptor 100-Issopro fuel,boost,egt,trans temp-Fluidamper-hx35-bhaf-over engineered engine vent tube
96 Suburban SLT 300k 2wd 6.5 turbo diesel with mods
krrz350 is offline
post #23547 of 23549 (permalink) Old 01-10-2020, 12:35 PM
ron73440's Avatar
Had a bit of a vibration during acceleration around 2000rpm.
Turns out the middle U-joint had some play. After removing the drive shaft I figured as long as I'm here, might as well do them all. Went with MOOG Super strength and borrowed a press kit from AutoZone.
Drive shaft came out easily enough, just heavy and awkward.
The bad one's end cap broke off instead of pressing out, so I found a socket that hit the sides of the cap without hitting the yoke and hammered it out.
The other 11 were perfect and I grease them every oil change, so I'm not sure what happened with this one, but they could be the original ones with 350,000 miles on them.
I had a little vibration for the past 3 or 4 years while braking during the last 10 mph that I could never find and eventually gave up on, turns out it was the U-joint because it is gone now.
ID:	864815   Click image for larger version
ID:	864817   Click image for larger version
2001 2500 4X4 QCLB, 5 speed, MBRP exhaust FASS FA D08 150G, BHAF, Edge Juice With Attitude
MOLON LABE
ron73440 is offline
post #23548 of 23549 (permalink) Old 01-10-2020, 08:07 PM
irish power mad's Avatar
Hi all, it's been some time since I was on. Still running the old 2nd gen and 3 weeks ago the power steering pump decided to quit with no warning and with 200 miles of driving to do. New pump fitted and thankfully the brakes and the ps are back but unfortunately I must have nicked a seal or something because I'm now loosing engine oil at an alarming rate from the rear of the vac pump. Is there an o-ring type seal in there?.
Am I the only one who knows everything?
01 3500 Dually Q.CAB, Quad Adr.,pulse, 4" straight stainless exhaust, air dog FP 150 fuel preporator, half inch draw straw and fuel lines.Rancho 5000 shocks rear, 9 way adjustable up front, 3.55 rear end.DIY built DTT trans, triple disc low stall Goerand tc,billet flex plate and input shaft, DTT shift kit, Holset HX40W 60/65/16 turbo(stock turbo propping the door open)125hp DAP injectors pushing on the pistons, BHAF and more to come
irish power mad is offline
post #23549 of 23549 (permalink) Old 01-20-2020, 03:59 PM
mthomp1's Avatar
Seat cushion w/ fabric and console lid replacement:
2001 Ram 2500, 24 valve, 47RE, 4x4, 3.55, short bed, quad cab, all stock
1996 Ram 3500 cab & chassis, 12 valve, NV4500, 4.10, flatbed, single cab, all stock
mthomp1 is online now
