Steering.... Pushing my steering wheel - Dodge Cummins Diesel Forum
post #1 of 13 (permalink) Old 02-11-2011, 07:03 PM Thread Starter
Chris U's Avatar
Well after a lot of work my steering is good and tight.
But there is still something that needs attention. While driving, I really get a lot of feed back into the steering wheel.... I bought a fox stabilizer from Thuren thinking this would help and it did some but when I go over bumps and heaves in the roads it pushes my steering wheel around... which can't be good for the steering box.
I don't recall this being an issue on my last 2nd gen... just not seeing what it could be.
There are 2 things I have not confirmed.
Toe - Could a slight toe out cause my steering wheel to get pushed? Don't seem likely. But I have a hunch I have some toe out issues.
Ball Joints .... can't confirm they are good, or bad. The tire wear is good and I do not get a any noise or feel anything going over bumps.... other than my steering wheel getting worked on.
I really noticed it more and more once I had everything reinforced and tight in the steering system.... now it's all transmitting road issues into the steering wheel instead of absorbing.
1999 CTD QCLB Auto 4x4- TST Comp/Smarty, Weston Injectors, ISSPRO, S&B, Intake, 5" Exh w/FTE Reasonator, BD SuperB turbo, Billet Triple Conv, Built Trans, Carli Suspension, King Pin Tops, Raptor 150 all 1/2" lines, drawstraw, ISSPRO Gauges, LineX Rockers
Chris U is offline
post #2 of 13 (permalink) Old 02-11-2011, 07:09 PM
On call 24/7
98whitelightnin's Avatar
iTrader Score: 16 reviews
Does it follow dips and cracks in the road?
1998 12v, 4x4, Club Cab, Carli, Thuren, BlueTop, Core 4x4
2012 Laramie Longhorn, EFI by Ryan, Carli, Thuren
1995 Dually, Weston's 5x.016, 4k GSK, 5" FloPro, 255/85r16 Toyo M/T, Goerend, ARP, 60# Springs, BW 62/65/14, BW 75/96/1.10, Isspro, Fass 125, BDP Sump, 7mm DV's, 751 HP 1883 FP Torque on NOS
1998 P-Pumped 24v, 4x4, NV4500 swap
98whitelightnin is offline
post #3 of 13 (permalink) Old 02-11-2011, 07:11 PM Thread Starter
Chris U's Avatar
Yeah it does some, but not as bad as when the steering was a mess. I do move the wheel in both directions more than seems normal, to compensate for crown also...
Chris U is offline
post #4 of 13 (permalink) Old 02-11-2011, 07:27 PM
On call 24/7
Have you adjusted the cam bolts in the lower control arms? I have my caster set so the front pushes down, dont know if its positive or negative but that helped my trucks steering alot.
post #5 of 13 (permalink) Old 02-11-2011, 07:29 PM Thread Starter
Chris U's Avatar
Yes, I've given the truck Caster, one notch from full on each side.
Chris U is offline
post #6 of 13 (permalink) Old 02-11-2011, 07:41 PM
On call 24/7
Thats about where I have mine set.
post #7 of 13 (permalink) Old 02-11-2011, 07:54 PM
runit02's Avatar
His truck has aftermarket coils and maybe sits higher. I'd add more caster bud.
Official CF repair crew
runit02 is offline
post #8 of 13 (permalink) Old 02-11-2011, 08:01 PM Thread Starter
Chris U's Avatar
It's about 2.5" higher in the front.... like a leveling kit. Does that usually want as much caster as I can put in it?
Chris U is offline
post #9 of 13 (permalink) Old 02-11-2011, 08:10 PM
runit02's Avatar
I'm running about 4.5* negative caster and can let go of the steering wheel on the freeway.
runit02 is offline
post #10 of 13 (permalink) Old 02-12-2011, 01:19 AM
jinpdx's Avatar
How are your tires wearing? What is the stock setting supposed to be?
2001 QCSB 4x4, Auto, HY35 w/ homemade J-hook, EGT, FP and Boost gauges, FASS HD150, 4in strait pipe, rebuilt trans with some mods, billet TC and reworked VB, Quadzilla Adrenaline
jinpdx is offline
post #11 of 13 (permalink) Old 02-12-2011, 10:44 AM
Banned
go to an alignment shop. a good one. they will tell you if your ball joints are bad, if they are not they will align everything for you; insted of just taking a stab at it. they may even adjust the preload on the gear box if you ask nicely
cumminsdog is offline
post #12 of 13 (permalink) Old 02-12-2011, 12:30 PM
runit02's Avatar
IIRC the stock setting is around 2 or 2.5* negative. I have 49000 miles on my procomp XMT's. They are feathered and rough but thats still some good miles IMO.
runit02 is offline
