Front upper Knuckle inserts - Dodge Cummins Diesel Forum
post #1 of 6 (permalink) Old 12-07-2019, 12:35 AM Thread Starter
LEARNtoKNOW's Avatar
So I'm doing some work on my 2 cummins. Swapping axles and what not. I'm rebuilding the front axles on both. One is a 99 and the other is an 01. The 99 was in a wreck and the left steering knuckle was bent so I'm tearing it apart and I noticed the upper ball joint tapered insert on the axle was broke and pretty destroyed. Does anyone know a part number or where I can get some replacements? Thanks in advance. I searched with no results. I could be calling it the wrong thing...? Thanks in advance!
Sent from my SM-G960U using Tapatalk
LEARNtoKNOW is offline
post #2 of 6 (permalink) Old 12-07-2019, 12:59 PM
#2 Makes Her Spool
Jhart11's Avatar
Man only thing Iíve seen like that is an adjustable camber ball joint, havenít worked enough on the second gens enough to know.
John
12' 2500
06' 2500 - R.I.P.
Jhart11 is offline
post #3 of 6 (permalink) Old 12-07-2019, 01:05 PM
#2 Makes Her Spool
Jhart11's Avatar
Is that truck a gasser? Looks like the camber bushing under the suspension >ball joint section in rock auto for a 99 - v10
John
12' 2500
06' 2500 - R.I.P.
Jhart11 is offline
post #4 of 6 (permalink) Old 12-07-2019, 01:59 PM Thread Starter
It's a 99 Cummins. But that looks like it. After talking to a buddy he said they are camber inserts. So I've been searching for that. Thanks for the help. These trucks have been a pain in the since day one haha.
post #5 of 6 (permalink) Old 12-07-2019, 02:00 PM Thread Starter
I guess that what they are. Which explains why one truck was -1 camber j believe the sheet said way back when I had an alignment done
post #6 of 6 (permalink) Old 12-08-2019, 02:00 AM
Yes that is what it is. Notice the hole is off center and has 6 positions. there is no front or back. It adjusts in and out for CAMBER, not front to rear for caster. Caster is done at the cam bolts on the lower control arms. Reason they are hard to find is they are seldom replaced due to not a wear part.
bigfish95971 is offline
The Following User Says Thank You to bigfish95971 For This Useful Post:
LEARNtoKNOW (12-08-2019)
