Driver and passenger seat cushion interchangeable? - Dodge Cummins Diesel Forum
 2Likes
  • 2 Post By nekkedbob
post #1 of 7 (permalink) Old 11-17-2019, 12:38 PM Thread Starter
Here's the deal:
My interior is in really good shape. The seats aren't torn up, but the driver seat cushion is not really a cushion anymore because the foam has mostly failed where most of the drivers weight is put on it. Passenger side is cushion looks like brand new and I was thinking that it looks pretty much identical to the driver's side and would feel much more comfortable to drive on. So how much of a teardown is it to get the cushions off and are they even identical in a way that they can be swapped over? Or is it even possible to get just the cushion off?
Also my truck has airbags, are there any sensors related to it on the seats?
2001 Dodge Ram 2500 4x4 Cummins + NV4500/NP241
Luoppis is offline
post #2 of 7 (permalink) Old 11-17-2019, 02:53 PM
On call 24/7
98whitelightnin's Avatar
iTrader Score: 16 reviews
The front corners might be different. Geno's sells them as driver and passenger side. The cushions are simple to get off though, four 10mm bolts holding the cushions to the frame. Once you get those off, the rest is self explanatory.
1998 12v, 4x4, Club Cab, Carli, Thuren, BlueTop, Core 4x4, BD Diesel, PDD 5x.012, South Bend
2012 Laramie Longhorn, EFI by Ryan, Carli, Thuren
1995 Dually, Weston's 5x.016, 4k GSK, 5" FloPro, 255/85r16 Toyo M/T, Goerend, ARP, 60# Springs, BW 62/65/14, BW 75/96/1.10, Isspro, Fass 125, BDP Sump, 7mm DV's, 751 HP 1883 FP Torque on NOS
1998 P-Pumped 24v, 4x4, NV4500 swap
98whitelightnin is online now
post #3 of 7 (permalink) Old 11-17-2019, 09:13 PM
Mine was as you stated. I found that if you removed the cushion and steamed it with a hand steamer it that it will go back to its original shape. I did mine about 4 years ago and it still looks good. Look up cushion steaming on U TUBE and you can see them do it.
98whitelightnin and Luoppis like this.
1998.5 2500, QCSB, 2500, 24v, 4x4, BHAF, BD boost fooler, waste gate valve, ISSPRO gauges, Fass DDRP
nekkedbob is offline
post #4 of 7 (permalink) Old 11-17-2019, 11:35 PM
Iíve swapped cushions on cloth & leather on 2 of my 01s. Seemed to fit fine. Mine were same way too, driver side pounded out & pass side like new.
2001 2500 ECSB 24v 5 speed mostly stock 460kms
2001 2500 ECLB 24v auto mostly stock 298 Kms
2001 2500 Reg cab 24v 5speed stock 524kms
Rubble65 is offline
post #5 of 7 (permalink) Old 11-29-2019, 10:07 PM
Monstermaker's Avatar
Yep itís just four bolts underneath, easy to do.
Theyíre almost identical, and will fit either side, but theyíre slightly different. Not enough that anyone but you would notice.
If you want new foam just order it from Genos.
If you want new upholstery, Katzkin makes fantastic leather kits and sells them for a great deal.
'99 QC 4x4 Dually.
In the near future Iím ripping out all the electronic junk and P-pumping it.
Built trans, Gear Vendors overdrive, Kelderman Air Ride
Monstermaker is offline
post #6 of 7 (permalink) Old 11-30-2019, 10:36 PM
If your going to do leather & your in a colder climate for winter, Iíd advise going heated too. I put used leather in one of the 01s without heat & didnít like it after -20 or below. Never really noticed til I got the 2nd 01 with heated seats, that non heated leather got pulled for cloth. Those heated leather seats are nice on those cold windy days where your in & out of truck all day. Seat warms you up instead of other way around👍👍
Rubble65 is offline
post #7 of 7 (permalink) Old 12-05-2019, 01:20 PM Thread Starter
Thanks for all the info guys. For me it might be a touch too expensive to have a new cushion shipped all the way across here so it might actually be cheaper to have an upholstery shop craft a new foam or try the passenger swap. I took a closer look and the passenger side is a bit gone too so it might just end up having the smushed side shift to the right side of the drivers seat after all if I went for the swap.
I've never heard about steaming a seat cushion back to life and thats something I want to try out if my cushion isn't all crumbled up.
Also I don't want to go for leather seats because they are a pain in the winter AND on those hot summer days. I got that sort of ruffled fabric on my seats and it's very nice because it's very breathable in summer and doesen't feel all that cold in the winter even though my truck doesen't have heated seats.
Luoppis is offline
