Has anyone found good battery terminals/ - Dodge Cummins Diesel Forum
 3Likes
post #1 of 16 (permalink) Old 08-04-2019, 11:27 PM Thread Starter
My battery terminals are not clamping well. Has anyone found good replacements?
There are nice $300 complete sets of cables but that price seems excessive especially because my cables are good without significant voltage drop. I'd like to simply replace the cable ends.
Here's a link to the $300 cable sets. https://www.custombatterycables.com/...-5-9l-cummins/
2000 LWB, Quad Cab, 4x4, NV4500, AirDog, Gauges, Thuren Track Bar, Lost crappy AGR and A1-Cardone steering boxes. RedHead is the best so far but truck has stopped returning to center. Hopefully, I'll get to it soon.
Junkman is offline
post #2 of 16 (permalink) Old 08-04-2019, 11:29 PM
Stormin08's Avatar
NAPA sells those same ends.
02 Sport / 47re / 4" MBRP TBE / DAP 75hp sticks/ HX35W / GDP FUEL BOSS / DDRP02 / 3rd gen brakes / 4th gen steering / 2" Thuren / MC ARMS / 5100's /285/75/17
Stormin08 is offline
post #3 of 16 (permalink) Old 08-05-2019, 01:00 AM
ofelas's Avatar
http://www.fostertruck.com/dodge/dod...ry-cables.html
R12 in the summer, Webasto in the winter, and cassette tapes all year.
ofelas is offline
post #4 of 16 (permalink) Old 08-05-2019, 01:05 AM
I bought those "military" battery terminals and made my own cables. The cable ends needed to be crimped on so I bought a cheap hydraulic crimper from Amaz0n, along with waterproof heatshrink, etc. It still cost a few bucks, but cheaper than the custombatterycables.
2001 Dodge 2500. 221k, 2wd qclb, allegedly built auto, 57mm Super B/s475, 6x.011 pdd injectors, Arp head studs, Edge JwA+CS, Fass 220, Hamilton pushrods, Crower 110#, .093 crossover tubes.
67baja is offline
post #5 of 16 (permalink) Old 08-05-2019, 01:35 AM
iTrader Score: 15 reviews
IMO it is hard to beat the robust and versatile "mil-spec" (i.e. meets US military specifications) terminals sold by Mcmaster Carr at about $5 each.
https://www.mcmaster.com/7738k2
xxwabbit likes this.
2005 SLT 4x4 QC LB G56, GDP horn, HDCAI, SBC ConOFE,
seafish is offline
post #6 of 16 (permalink) Old 08-05-2019, 01:41 AM
ploobr is offline
post #7 of 16 (permalink) Old 08-05-2019, 02:08 AM
PTSCummins's Avatar
I made the jump to group 31 batteries with 3/8 ring terminals a long time ago.
I had a D5 come close to burning down when a loose clamp terminal caught fire while restarting the machine after a lunchbreak. After that I won't have clamp terminals on my trucks or equipment.
Sent from my SM-G930W8 using Tapatalk
1999 Ram 2500 QCLB - SO 24V in front of NV4500 and SB DD 3250. Fresh rebuild with ARP studs, CR head, 150HP F1s, Raptor 100, Quadzilla Adrenaline and HX35/S475 (1.10)
PTSCummins is offline
post #8 of 16 (permalink) Old 08-05-2019, 08:38 AM
ofelas's Avatar
Group 31 stud terminals are definitely where it's at, haven't used anything else for years.
However, when finds a spare pack, can't let them pretty brass screw on posts go to waste, and hence the military clamp add on; sure makes covered uni directional routing of the cables a lot neater.
No need to disturb the short bolts that fix the clamps to the posts; think of the clamps as part of the battery after the initial installation.
Has anyone found good battery terminals/-fullsizeoutput_e1f.jpg
Rockyhud likes this.
ofelas is offline
post #9 of 16 (permalink) Old 08-06-2019, 03:11 AM
Military terminals like in pic above. Lugs on cable. Got mine from Battery Bill's in Sacramento, a commercial battery shop. Half the price for cable, or better than Napa and other parts stores.
bigfish95971 is offline
post #10 of 16 (permalink) Old 08-06-2019, 08:15 PM
HMH
Go this route and never look back. Where my other battery was I have a tender mounted.
98 24v 4×4 5 speed edge evo fass drp
ΜΟΛΩΝ ΛΑΒE
HMH is offline
post #11 of 16 (permalink) Old 08-06-2019, 08:25 PM
I went with the Napa ones about 10 years ago. Had to torch solder them, kept my old wires... all good. 1996 model. I’m on a budget and conservative, don’t mind dropping $$$ if I have to, but didn’t have to in this case.
96- 12v LB EXCab, Auto Trans, 10 fuel plate, 3K gov springs, 4" diamond eye exhaust, 18° timing, glow shift gauges, trans upgrades.
Tom 5.9 is offline
post #12 of 16 (permalink) Old 08-06-2019, 09:28 PM
I bought different size ends in bulk, and shrink tubing in proper colors, from the custombatterycables.com for cheap and modified my factory cables. I just cut the battery terminals off and crimped and soldered the eyes on and put shrink tubing over them. Turned out nice. Even if you keep top post batteries you can use various ends to adapt them to your cables with eyelets. I'm trying brass terminals on my 2006 now.
I bought the hydraulic crimper off Ebay for about 50 bucks. That expense was worth it because I have used it on two trucks, and counting.
First pic shows the 2006 switchover with a temp battery terminal while I waited for the brass ones to come in, and the second is the adaptation of the brass terminals since I had more cables than the little bolts that came with the terminals could handle.
Chris
Artificial Intelligence is no match for Natural Stupidity.
2006 2500 CTD, 4x4, MC, AT, loaded. Now Overvalved AND Undervalved (got a 96 )
http://www.Stamey.Info/Truck
TORQUIN is offline
