Pulse Monitor Modification (no more bad buttons!) - Dodge Cummins Diesel Forum
post #1 of 22 (permalink) Old 10-31-2009, 09:12 PM Thread Starter
dknaks's Avatar
Well folks, I finally got REAL sick of my malfunctioning buttons on my Pulse Monitor for my Quadzilla Adrenaline. The contact pads always seems to loose connectivity and every time I cleaned them they would last about a day. I was going to buy new buttons but decide to change the switch type completely instead. Changed to a tactile switch instead (used on most TV and Electronics controls boards i.e. volume up and down). Was a fairly simple job, with the only scary part being the modification of the plastic frame with a dremel.
Here are a few pics.
Front shot of Before.
Removed four screws from rear cover.
Rear Cover removed. Try to keep the sticker with the rear cover so it doesn't get in the way later.
Removed two screws from control board and pulled control board from unit.
Shot of the back side of the board.
Three of four buttons installed. Used double sided adhesive between the tactile switch and the board, also had to manipulate the button legs to fit, and cut off the two extra legs kitty-corner from one another.
Rear shot of buttons soldered in place.
Buttons installed.
sockets ground down from the rear with a dremel tool. This part take some work. I ground a little at a time. You have to take off about 1/8th of an inch.
Buttons seated back in the faceplate.
Finished product! Cut the buttons with a real sharp dikes.
Cut the buttons off level.
Here are the switched I used in replacement of the contact pad type used in the monitor.
Now it works great, you push the button once and it does what its supposed to. Should have done this a long time ago. Thought I'd share the idea if other are having troubles.
-07 6.7 3500 dually, Blackmaxx, SB DD3600. Fully deleted.
dknaks is offline
The Following 3 Users Say Thank You to dknaks For This Useful Post:
jigabop (12-05-2009), MR.B (11-01-2009), Powerwagon64 (01-24-2011)
post #2 of 22 (permalink) Old 10-31-2009, 09:20 PM
Nice mod!
Wonder if quad will update theirs now?
1998.5 Dodge 2500 4x4 QC/SB 24V Cummins Diesel. 5 Spd. Espar D5. Dipricol FP, Quad ADR/Pulse, VP not tapped, AirDog FP150, 200,000 Miles. 3rd Gen TB&DSS, Lightforce 170s, Armorthaned Rockers/Fenders. DLUX Hubs Carli Suspended/Bilstein 7100s
BORGESON OVERHAUL
David_411 is offline
post #3 of 22 (permalink) Old 10-31-2009, 11:59 PM Thread Starter
dknaks's Avatar
Well I took the truck on a test drive tonight, and it is real nice to push the button once to simply go up a power level instead of holding it down only to have it jump three or four levels. I hope quadzilla makes note of this idea. Most only add a few bucks to each unit during the build process. My total cost was 2 bucks for the switches and an hour or two of time.
dknaks is offline
post #4 of 22 (permalink) Old 11-01-2009, 12:16 PM
MR.B's Avatar
Great idea I will keep this in mind when my buttons go out. right now they work but some times I have to push hard and hold them down.
2000 4x4 auto aem workhorse intake cfm+ s300 3rd gen track bar conversion bd steering stabilizer
4"exhaust rv275 fass 95 Adrenaline w/pulse
MR.B is offline
post #5 of 22 (permalink) Old 11-02-2009, 03:09 PM Thread Starter
dknaks's Avatar
I may be willing to do the repair for a small price if folks are interested. Mine is still workin great!
dknaks is offline
post #6 of 22 (permalink) Old 11-02-2009, 04:59 PM
GloNDark's Avatar
Originally Posted by David_411 View Post
Nice mod!
Everyone hold their breath!!!
I absolutely HATE the buttons my pulse. I'm going to sto
