anyone want to see a SUPERIOR shift 48RE shift kit install ??
this is for the 48REI can't find the difference in the 47re/48re vb's. I have to switch back and forth between the pictures as I can't see them on my screen at once. Can you point it out? Thanks
I've never tried to change band in vehicleGreat demo Baxi. My question is if I send you my VB, how much to do all that cool stuff to it then mail it back for me to install?
Also, are you replacing that week band that goes around the drum. My tranny guy replaced it while on the truck by grinding away a small portion of the band. It worked okay for a couple thousand miles but now does the same thing. Second gear slip and lazy shifting. It help would be appeciated..Mike
this kit addresses all of the built in problems the 48RE hasAssuming it's finished, what's the end result on the performance increase?
It really isn't tough once you have it in front of you :thumbsup:Yeah if I have to start drilling and notching stuff on the valve body to make it work I think I will leave it to someone else. I would really love to have it done for sure though
Who makes the hd2 kit and what power levels would the superior kit be good for?this kit addresses all of the built in problems the 48RE has
it is head and shoulders above a stock VB but definatly less capacity than an HD2 kit
