1999 p-pump 24v trans not shifting - Dodge Cummins Diesel Forum
98.5-02 24V P-Pump Conversion Discussion of converting 24V trucks from the VP44 stock pump to a P-Pump powered 24V No Advertising ...NO ADVERTISING
post #1 of 11 (permalink) Old 07-08-2019, 12:30 AM Thread Starter
Kramer_12v's Avatar
1999 p-pumped 24v trans wont shift out of first had a noise box on it I took it off started to not shift put noise box back on it shifted all the way to third but no power.
Mods are
Pictured
Kramer_12v is offline
post #2 of 11 (permalink) Old 07-09-2019, 01:14 PM
9297oldram's Avatar
I see you have a Firepunk trans, maybe call then and tell them your problem. What do you mean shifted to 3rd and no power, the engine had no power?
9297oldram is offline
post #3 of 11 (permalink) Old 07-10-2019, 12:51 AM Thread Starter
Kramer_12v's Avatar
Yes it shifted to 1st,2nd,3rd motor had no power. I bought it off of some older guy he said it had a firepunk but no papers for trans
post #4 of 11 (permalink) Old 07-10-2019, 07:09 AM
9297oldram's Avatar
Does it have a fuel pressure gauge, sounds like maybe a fuel problem if the engine has no power. What is being used for the transmission to shift into OD and LU?
post #5 of 11 (permalink) Old 07-10-2019, 08:07 PM Thread Starter
Kramer_12v's Avatar
Yes has fuel pressure gauge at. What do you mean what is being used?
post #6 of 11 (permalink) Old 07-10-2019, 08:33 PM
Stormin08's Avatar
do you still have the stock 24V pcm ? or an aftermarket trans controller ?
02 Sport / 47re / 4" MBRP TBE / DAP 75hp sticks/ HX35W / GDP FUEL BOSS / DDRP02 / 3rd gen brakes / 4th gen steering / 2" Thuren / MC ARMS / 5100's /285/75/17
Stormin08 is offline
post #7 of 11 (permalink) Old 07-10-2019, 09:45 PM Thread Starter
Kramer_12v's Avatar
I'm not sure as i didnt do the swap anyway to tell
post #8 of 11 (permalink) Old 07-11-2019, 07:58 AM
Stormin08's Avatar
go trace the wiring....the pcm is located on the firewall behind air intake box.
ir start at the trans connection and work up from there (probably tell more by this method)...
just chase the harness from the trans back, any splices, cut wires ect....list all.
post #9 of 11 (permalink) Old 07-11-2019, 08:14 AM
9297oldram's Avatar
Firepunk has there own controller. Does your fuel pressure drop down low when there is no power?
post #10 of 11 (permalink) Old 07-11-2019, 10:12 PM Thread Starter
Kramer_12v's Avatar
no sir it stays at 60psi
post #11 of 11 (permalink) Old 07-12-2019, 06:10 PM Thread Starter
Kramer_12v's Avatar
Well I found out that the tps bracket isnt mounted I thinking that could be part of my problem😂🏼
