Egts out of control - Page 2 - Dodge Cummins Diesel Forum
98.5-02 24V P-Pump Conversion Discussion of converting 24V trucks from the VP44 stock pump to a P-Pump powered 24V No Advertising ...NO ADVERTISING
 2Likes
post #13 of 15 (permalink) Old 05-26-2019, 09:34 PM
Cummins_freak777's Avatar
You could always try the cheapest route first and build up from there till you're satisfied with the end outcome. Porting and polishing can get quite expensive. you might start with a cam first or if you want to keep stock cam do a stage 2 head with porting around the valves and on the exhaust side would be a little more economical. If youre not concerned with being cost effective you could just go full tilt and knock off the intake shelf and do it all. Personally I would probably try the turbo on the stock head just to get a baseline for how it feels and if you like it or not then start working up from there. You could do the cam next and then the head. I was going to try it with a stock cam because Im stubborn and I don't think its completely necessary but it will work to your advantage to have a bigger cam. The biggest restriction is in the head at the intake shelf so milling the intake of would actually help the cam even more since the restriction zone is actually before the valves themselves.
Anyone can port and polish if they know what they're doing. You really just need a small drimmel tool and some stone bits and maybe a steel bit or two. However I probably would still have someone do it because when you cut the intake off then the side of the head has to be milled flat so that you have a good sealing surface for your new intake shelf. Plus performance machine shops are going to be a little better at it than one of us who is trying to learn on their first head. Im not sure where you are located but im sure you could ask around and find someone who can do it. I'm in the heartland of sorts for this kinda stuff so i could be at some very big name shops to do this type of work in probably 3 hours or so.
02 6 spd QCSB, drag comp, DAP 7x.012 VCO, 63/68/14 sxe, ARP 2000, hamilton 103, hamilton pushrods, SB 3250, 5in exhaust, Fass 150, follow me on instagram @pr0ject_blue
94 sclb dually tuned and 3kgs
Cummins_freak777 is offline
post #14 of 15 (permalink) Old 05-27-2019, 10:20 AM Thread Starter
Ya I’m in Vermont so there are only a hand full of small shops that specialize in motor work none realy specific to diesels
Teamramrod is offline
post #15 of 15 (permalink) Old 05-27-2019, 12:53 PM
You might be able to call some of the bigger name shops and see if they have any cores they can build for you and then you ship your cylinder head back to them once you get the core in.
Similar Threads
Code list Bwgas1 2013-2018 General Discussion 6 10-31-2014 07:00 AM
P1222 help can't figure it out!! Ryker Peterson 3rd Gen. Powertrain 27 04-12-2014 06:03 AM
P2149 resolution Taquache 3rd Gen. Powertrain 45 11-27-2012 11:19 PM
