P pumped with cruise control? - Dodge Cummins Diesel Forum
98.5-02 24V P-Pump Conversion Discussion of converting 24V trucks from the VP44 stock pump to a P-Pump powered 24V No Advertising ...NO ADVERTISING
post #1 of 11 (permalink) Old 01-15-2019, 06:56 AM Thread Starter
custom user title
thepureface's Avatar
Hey guys on my 2000 I’m wondering if it’s possible to hookup the cruise control?
If so any info on how it’s done?
2000 4x4
Built Auto
phatshaft 62 over s475
DOR steering+suspension
P pump swapped
thepureface is offline
post #2 of 11 (permalink) Old 01-15-2019, 03:30 PM
Not 100% sure about 00 but my 99 has a vacuum operated cruise control with a fly by wire connected to the tps (left mine on the truck). So long as there isnt vacum leaks and the cable is hooked up to the throttle it should work as intended. The module has a electric connection as well, I'm guessing to get speed input from the ecm/pcm.
99 Ram 3500 SLT 4x4, P24v, ZF6-750, s362/475, 7x0.014, supporting mods.
marco610 is offline
post #3 of 11 (permalink) Old 01-15-2019, 04:34 PM
My understanding is if you have the electronic cruise setup your SOL. My 2001 has the vacuum, I used a crazy Carl throttle bracket to keep the APPS and cruise cable in hopes the cruise will work. Haven't ran it yet though.
2001 QCSB 2500 maxd 215ppump,7x.014s,S300/S400 Hamilton188/[email protected],street/strip project.
2012 CCSB 3500 Leveled,Black Maxx,Flo pro
DJRobinson is offline
post #4 of 11 (permalink) Old 01-15-2019, 05:55 PM
On call 24/7
98whitelightnin's Avatar
iTrader Score: 16 reviews
After I p-pumped my 98, I jabbed a screw driver in the apps, making the springs stick in one spot. I used my scan gauge and set it to 20% throttle and left it dangling. Cruise was smoother after p-pump than it was with vp
1998 12v, 4x4, Club Cab, Carli, Thuren, Mostly Stock
2012 Laramie Longhorn, EFI by Ryan, Carli, Thuren
1995 Dually, Weston's 5x.016, 4k GSK, 5" FloPro, 255/85r16 Toyo M/T, Goerend, ARP, 60# Springs, BW 62/65/14, BW 75/96/1.10, Isspro, Fass 125, BDP Sump, 7mm DV's, 751 HP 1883 FP Torque on NOS
1998 P-Pumped 24v, 4x4, NV4500 swap
98whitelightnin is offline
post #5 of 11 (permalink) Old 04-02-2019, 12:28 PM
ODIEUB's Avatar
iTrader Score: 8 reviews
Should be able too. My old 01 i 12v ed i did with a 12v tps. Now the only trucks ive ever seen that was electric cruise is manual 4 wheel disc brakes. And thats late 01-02
01 HO w/215 12v, ddp, helix II, sbc dd, 240k
01 2wd quad cab, 24v 234k 6-speed- 215 12v in the works
95 1500 rc sb 2wd p7100 24v auto being incubated
ODIEUB is offline
post #6 of 11 (permalink) Old 04-09-2019, 08:18 AM Thread Starter
custom user title
Alright, im going to have to look into this in the next few months. Cruise is nice on the highway.
Thanks
2000 4x4
Built Auto
P pump swapped
post #7 of 11 (permalink) Old 04-10-2019, 05:43 PM
chummy's Avatar
My 02 cruise works after the swap with a Crazy Carl apps bracket.
02 2500 Sport QCSB 4x4, P7100, Built 47re, DAP 7x.012 sac, 66/73/.80 sxe
07 5.9 2500 CCSB 4x4, 48re, Stock
chummy is offline
post #8 of 11 (permalink) Old 04-10-2019, 05:45 PM
ODIEUB's Avatar
Thats cause its an auto that had oem vacuum cruise. Stick trucks 01-02 with disc brakes i dont think had that option.
ODIEUB is offline
post #9 of 11 (permalink) Old 04-10-2019, 07:20 PM Thread Starter
custom user title
I just was working on truck and found my issue. My vaccum pump L shaped rubber boot is cracked.
No idea where to get a replacement.. any suggestions?
2000 4x4
Built Auto
P pump swapped
post #10 of 11 (permalink) Old 04-10-2019, 07:47 PM
On call 24/7
You can get an elbow at napa Dorman #47092
post #11 of 11 (permalink) Old 04-11-2019, 08:23 AM Thread Starter
custom user title
Thanks alot
2000 4x4
Built Auto
P pump swapped
