Cam wont come out!!!! - Page 2 - Dodge Cummins Diesel Forum
98.5-02 24V P-Pump Conversion Discussion of converting 24V trucks from the VP44 stock pump to a P-Pump powered 24V No Advertising ...NO ADVERTISING
 4Likes
post #13 of 17 (permalink) Old 01-08-2019, 08:46 PM
Ouch! If the cam looks like that the block cant be any better. Ive also heard of people line boring and putting cam bearings in.
dd453ford likes this.
99 Ram 3500 SLT 4x4, 19.5's, P24v, ZF6-750, s362/475, 7x0.014, supporting mods.
marco610 is offline
post #14 of 17 (permalink) Old 01-08-2019, 10:19 PM
Davis Cummings's Avatar
Originally Posted by sven View Post
From my understanding there is only a cam bearing on the front journal, I know that some of the performance motor builders bore the cam bore out and put bearings on all the journals, it might be worth looking into.
This should work. Take it apart and send it all off to a good engine machine shop. They will tell you if a new block is warranted. Good luck & please, no more port-a-powers under the hood.
2018 Ram 2500 HD 6.7L AT/6 4X4
Plain Jane Tradesman - nicely equipped
Davis Cummings is offline
post #15 of 17 (permalink) Old 01-16-2019, 11:55 PM Thread Starter
Matt Garrett's Avatar
The block looked to be fine. I cleaned it up very well. Got a new cam and lubed the hell outta it. New cam bearing and it felt very very tight. No resistance when rotating it in. Hopefully i get another 300thou out of it ?? 😁
sven likes this.
Matt Garrett is offline
post #16 of 17 (permalink) Old 02-13-2019, 03:47 PM
Tructor03's Avatar
THis thing running yet? Curious to know how you made out.
Bought 100% stock, 3500. QCSB. 6spd. 35's w/revtek 2.5" leveling kit, AFE stage 2 w/intake elbow in 4" turbo-back MBRP.
2010 Mega Cab 3500 Cummins. EGR delete. DPF delete. MBRP 4"TBE. H&S Black Maxx
Tructor03 is offline
post #17 of 17 (permalink) Old 02-13-2019, 06:18 PM
sven's Avatar
he has another thread here, It is/was running but fighting a pump/timing problem
01 Sport QCSB, 55 block, nv5600 w/Fast coolers, valair org dd, fass 150,studded,dap 7x.013vco, ps62/475, Quadzilla Iquad, Timbo APPS, AFE blade runner, PacBrake PXRB, 5" exh, leveled, 285s,neon valve springs, 08.5 steering, fox stabilizer, redhead box
sven is offline
