HX35 annoying air leaks - Page 3 - Dodge Cummins Diesel Forum
post #25 of 32 (permalink) Old 09-06-2006, 11:26 PM
Trapper's Avatar
Was going to do a set of compounds but I needed a different trans controler:fist:
Trapper is offline
post #26 of 32 (permalink) Old 09-11-2006, 11:04 PM
Trapper's Avatar
Hey I found one on ebay, its a GTA4294http://cgi.ebay.com/ebaymotors/Garrett-GT42-GTA4294-Turbo-Turbocharger-Diesel-like-new_W0QQitemZ250026500829QQihZ015QQcategoryZ33742Q QrdZ1QQcmdZViewItem
It's wastegated.
Trapper is offline
post #27 of 32 (permalink) Old 09-12-2006, 10:42 AM
signature600's Avatar
Yeah, but that charger is WAY bigger than what Got...Diesel has. It's 71mm S400 size...like a K31
They do work well on a nitrous assisted drag truck though
Chris
It's gotten too bad to list everything I'm spent money on...
signature600 is offline
post #28 of 32 (permalink) Old 09-13-2006, 10:38 PM
Trapper's Avatar
So it would make a great big turbo, and something in the gt 37 for the small one?
Trapper is offline
post #29 of 32 (permalink) Old 09-14-2006, 10:03 AM
The GT42-94's would be good to maybe 500 on a 12v...you might be able to squeeze more out of it with timing and some fancy wastegating....but it's a little smaller than the standard S400's. It will spool better though.
Right now, we're using one on a 4400RPM 12v w/Nitrous. Spools about 2200RPM, and ran an 11.80 in Atlanta. Only fueling mods are Laser Cuts, 370's, 4K, and cut plate. Also running a H2 Cam!
A GT37/GT42 combo would be a sweet spooling set of chargers, but I THINK they would be out of steam before you made 550 on a 12v...but who knows. The Garretts aren't used very often on Cummins.
I'm gonna give it a shot once I get a tranny...only I'm aiming a little bigger
Chris
post #30 of 32 (permalink) Old 09-14-2006, 06:08 PM Thread Starter
Guest
yeah, I've given up on the 4288 for a secondary. With us moving in 6 weeks I don't wanna re-invent my secondary charger system and in light of no favorable turbines for it, it would take a pretty extensive re-work and R&D time to get it right. So my plan is to leave the 35 on top with it's modified turbine, and an unmolested BHTB3 on bottom (or side LOL). This way when I pass through Vancouver, I can dyno a 160 pumped, budget twinned truck to see just what the combo is capable of. I'm pretty maxed out everywhere that most guys would do with a budget in mind, so this test should be the end-all for the small pump, easy twin applications. So let's hear some horsepower guesses (always a fun Q) for #2 only, and then squirted with methanol. I'm hoping to crack 500, and would be happy with anything above or around that for now. Once we're settled, the march will continue.
oh, and BTW.....back to the original post, a thin bead of high temp silicone sealed up the compressor fine....but without caging the retaining ring with machine screws, the tendancy for it to pop is still there. I check it now and then and it does move around some with the high pressures.
Chris
got...DIESEL? is offline
post #31 of 32 (permalink) Old 10-23-2008, 12:35 PM
Jobless's Avatar
Sorry for the thread ressurection but this is exactly the issue I am having.
Has anyone had this issue and successfully fixed it with high-temp RTV?
Originally Posted by got...DIESEL? View Post
The compressor is sealed now....a thin bead of high temp sili worked nicely once allowed to cure overnight.
Jobless is offline
post #32 of 32 (permalink) Old 03-19-2012, 08:18 PM
1987chummins4x4's Avatar
Im having the same issue except it the exhaust housing putting black smoke everywhere and wont spool
94 2500 4x4 rclb fletcher cam,compounds, my lifesavingS
08 qcsb Laramie 4x4 Efi by lee Allgood, mbrp duals, s and b
1987chummins4x4 is offline
