fixing the trans - Dodge Cummins Diesel Forum
post #1 of 11 (permalink) Old 08-01-2006, 08:26 PM Thread Starter
fixing the trans
i'll take any opinions i can get. i'm needing to look into upgrading my tranny a lot sooner than i was planning. i know i'll be happy with the engine putting out 300-350 horse power. don't feel i need anymore for what i do with it. i don't tow anything, ever. i might get conned into towing father in law's 5000 lb camper one or two times. but that's pushing it. so what can i get by with? the truck has 65k original miles on it. can i get by with just a converter and valve body? or a stock rebuild with converter and valve body? do i dare trust this to someone like kennedy or aamco? i know i can install the converter myself and i can probably tackle the valve body as long as there aren't any special tools i need. do i really need a triple disc and billet shafts for what i'll be doing?
ok...lemme have it.
johnnychimpo is offline
post #2 of 11 (permalink) Old 08-02-2006, 12:06 PM Thread Starter
anybody have any insight here?
post #3 of 11 (permalink) Old 08-02-2006, 01:32 PM
Tech Specialist
a converter and a vb will be fine at that level.
97 dually 500 plus, 98 quad 12v wifes, and the toy a 98 reg cab short bed with a hx40 and ht3be
gunracer1 is offline
post #4 of 11 (permalink) Old 08-02-2006, 01:57 PM Thread Starter
yeah??? should i get mine rebuilt first or just install the conv and vb? any special tools for the vb? i've done them in gm's but never a mopar trans.
thanks for the reply!!
post #5 of 11 (permalink) Old 08-02-2006, 04:40 PM
got...DIESEL?'s Avatar
nothin special except some good pressure gauges. You have to be able to see cross leaks if they are there and fix them before they fix your trans good for you. You'll also need the gauge to set pressure. Follow the 6 or so test procedures in the DC manual. For that matter I would do the tests anyway to verify the condition of all the sealing rings and servo/pistons before putting any money into it. A leak now will only get worse with a higher pressure valve body, and it may change your course knowing what shape the hydraulic system is now before you start. These engines WILL find the weakness of a trans in a hurry. Just ask them, they'll tell ya.
Chris
In NW Florida? Get a hold of me...it's time Dodge makes it statement in these parts!!
'95 2500 Std Cab 4X4...
DTT billet trans and billet triple disc, billet flexplate, compound turbos, AEM Dryflow, 160 pump, custom plate, 191's, EDM370's, peaked and tweaked AFC, rack control plug, 20*, 3K, head studs, marine +.020 HG, Water/meth
got...DIESEL? is offline
post #6 of 11 (permalink) Old 08-02-2006, 05:58 PM Thread Starter
yeah that makes sense. thanks, chris. i'll have to find a way to get that checked out before i go any further. i heard a while back that if you run these 1 quart overfull it makes them grab a lot better. any truth to it or is this a vicious rumor?
post #7 of 11 (permalink) Old 08-02-2006, 07:27 PM
The best (in my opinion) is to put in a rebuilt tranny. Dave Goerends has an awesome tranny. You can also PM member Spicyjam since he is a Goerends dealer too. If you want to try one just come up to Hinckley and try mine. I am working in Pine City and staying in Hinckley at the Casino.
Tom
Contact me at:
Tom05 is offline
post #8 of 11 (permalink) Old 08-02-2006, 07:37 PM
I like te reliability of a perfromance rebuild myself. no worries, no stuff happens later. No little things later. NADP is great as is Suncoast. Suncoast is more money.
2016 3500 4x4, Aisin, 19.5's
2005 2500 4x4, 48re, leveled, 35's
2003 F250 4x4, 7.3L, 35's
Diesel Nut is offline
post #9 of 11 (permalink) Old 08-02-2006, 08:06 PM
Banned
Tranny
Since your gonna have the tranny out anyway, why not put new clutches in it. I would call Dave Goerend(gbtranssmissions.com) and tell him what you are wanting to do. You should probably replace the input shaft/hub if your going to be towing. So many of those have hairline cracks after 50K. I would probably just go billet and be done with it. Call Dave Goerend (563-778-2719) he will square you up.
zstroken is offline
post #10 of 11 (permalink) Old 08-02-2006, 08:39 PM Thread Starter
yeah. seems to keep coming back to getting ahold of dave. man that's a monster chunk of change. but i don't like throwing good money after bad. thanks for your input, guys. really appreciate it.
post #11 of 11 (permalink) Old 08-03-2006, 06:32 PM Thread Starter
i did some checking today. for me to buy a torque conv and vb and then have my trans rebuilt, i'm close enough to the cost of a goerends to justify paying the extra for one of theirs. you guys were right with your advise. again, i appreciate it.
