Emergency brake doesn't work - Dodge Cummins Diesel Forum
post #1 of 9 (permalink) Old 04-29-2013, 02:03 AM Thread Starter
rideordie1113's Avatar
My emergency brake is on my to-do list... It doesn't work at all currently. When I bought the truck it would hold slightly, and I figured it just needed adjusted.
I pulled the handle to release it and the handle is now stuck out and will not go back to the normal position.
I tried searching but didn't have much luck. Anybody have similar issues? Stretched cable(s)? Need adjusted?
1994 Ram 2500, 5 speed, 4x4 - 370 injectors, head studs, Valair ceramic DD
New/potential owners of 12 valves, read this..
rideordie1113 is offline
post #2 of 9 (permalink) Old 04-29-2013, 12:06 PM
There is no adjustment for the cable, the only adjustment is to adjust your rear brakes.
Adjusting Drum Brakes
Bill
'95 2500 4wd auto
'95 3500 5 speed heavy hauler
Stock for one day
illflem is offline
post #3 of 9 (permalink) Old 04-29-2013, 01:02 PM
country_hick's Avatar
If your parking brake pedal assembly itself is the problem here is how to fix it.
Parking Brake Fix! How to post photos?
1997 3500 club cab 3.54 gears towing & camper pkg. Still stock with a built transmission at 120k. 4" exhaust, 4kgsk, and exhaust brake waiting for installation. 37337 upgrade. Still need ideas for improvements for hauling 15k fifth wheel.
country_hick is offline
The Following User Says Thank You to country_hick For This Useful Post:
rideordie1113 (04-29-2013)
post #4 of 9 (permalink) Old 04-29-2013, 10:51 PM Thread Starter
Thanks for that link country hick.
I'm assuming (without having torn anything apart) that the spring fell off of that assembly..I'll give that fix a shot when I have time and see if that fixes everything.
post #5 of 9 (permalink) Old 05-01-2013, 04:13 PM
ihredneck's Avatar
I've got a spare assembly floating around, let me know if you need it
1992 W350 5-speed 4x4 Full Restore
1999 1500 RCSB w/ 2002 Drive Train 6-spd 4x4, stock
2006 3500 CCLB 6-sped 4x4, stock
ihredneck is offline
post #6 of 9 (permalink) Old 05-01-2013, 08:24 PM Thread Starter
Did a little bit of diagnosing today. it has good tension when set..the issue is that the when you release it, it does not pull that lever back down. if you manually pull down the lever, the parking brake functions perfectly fine. when you release it, it doesn't work again unless manually pulled down again.
does reversing the spring fix that?
post #7 of 9 (permalink) Old 05-02-2013, 08:48 AM
ihredneck's Avatar
sounds like maybe a kinked cable on the lever or where it hooks to on the brake mechanism is slightly gummed up
post #8 of 9 (permalink) Old 08-05-2013, 11:59 PM
natemoses13's Avatar
I'm having a parking brake issue too, but mine is that the spring that pulls the cable isn't engaging when you push the pedal. Is the only option to fix this replacing it?
2017 2500 mega auto
2000 2500 QCLB NV4500. Valair DD. 3.55's. 7x.009's. Edge Comp.
1999 3500 QCLB 47re. 4.10's. Quad Adr. FASS 150
1996 2500 QCLB Built 47re. 3.55's.
natemoses13 is offline
post #9 of 9 (permalink) Old 08-06-2013, 12:09 AM
The Digital Bullet
Common's Avatar
Bill, you know I'd never dare doubt you, but my parking brake has a stud and a but that you can tighten up to take out slack.
Or is it for something else?
TOTALED 3/23/16
| 1997 Ram SLT 4x4 | 3.55 | Dual Optima Red Tops | AFE Stage 1 | 5" Exhaust | MBRP 6" Tip | ARP Head Studs | TST #10 | 5 X 14 | 4K | 60LB | Air Dog 150 | ATS Aurora 3000 | South Bend 3600 | Auto Meter Pyrometer, Boost and Fuel Pressure Gauges | 20* | PEAK IC Boots |
FOR A QUICKER RESPONSE: [email protected]
Common is offline
