vacume leak - Dodge Cummins Diesel Forum
post #1 of 6 (permalink) Old 06-07-2006, 07:50 PM Thread Starter
Question vacume leak
Quick question about the vacume pump on my 98 12v. I noticed it was knocking and that my heater workes than dosent. And also noticed that you can here a small ticking sound at the fuel tank and it not a exhaust leak. any ideas? Could it be the vacume pump or some thing else? thanks
boatwork_jay is offline
post #2 of 6 (permalink) Old 06-08-2006, 05:34 PM
12valve's Avatar
are all the hoses connected, complete (not cracked)?
there go 2 small plastic vacum hoses to the top of the front end cab, which tend to break when messing around in the inj. pump area...
my 98 12valve has that same ticking noise at the fuel tank. dont know, but I have noticed it on more then one 98 12v
12valve is offline
post #3 of 6 (permalink) Old 06-08-2006, 05:46 PM
oldsmokey94's Avatar
my truck has a ticking sound sometimes too
dunno what it is
twins, rpm, fuel and some small extras.
COMPETITIONDIESEL.COM
oldsmokey94 is offline
post #4 of 6 (permalink) Old 06-08-2006, 07:11 PM
12valve's Avatar
dunno what it is
i have noticed a ticking of the lift pump, when the overflow valve is too tight!
but at the fuel tank... dont know...
12valve is offline
post #5 of 6 (permalink) Old 06-08-2006, 07:17 PM
fordcummins's Avatar
If heat comes on intermittenly...you may want to check the blower motor, or brake booster..mine was doing that before I replaced the booster. Take the hose off of the line from the vacuum pump going to the booster, start the truck and see if it has vacuum.
-JJ
Tow rig: 93 dodge, 1st gen. IC.
Puller: Ford 3.0, rockwell, drop box, reverser. unknown motor
Smiths Bell and Clock = work
fordcummins is offline
post #6 of 6 (permalink) Old 07-31-2006, 01:58 PM
iam gitting a ticking noise also near the gas tank. i dont know what it could be. it has 283000 miles so iam not surprised anymore.
orwsam is offline
