94 clutch master cylinder with 99 slave is this bad? - Dodge Cummins Diesel Forum
post #1 of 9 (permalink) Old 03-20-2012, 09:32 PM Thread Starter
1987chummins4x4's Avatar
I swapped my manual from a 99 and used everything but used my 94 master cylinder from before. Clutch is pretty easy but it doesnt take much travel to move it. I tried putting a 94 slave on but the fitting on the 99 line is too big for the 94 slave. Should i lightly drill the slave out or just return it?
94 2500 4x4 rclb fletcher cam,compounds, my lifesavingS
08 qcsb Laramie 4x4 Efi by lee Allgood, mbrp duals, s and b
1987chummins4x4 is offline
post #2 of 9 (permalink) Old 03-20-2012, 09:50 PM
crewcabstripper's Avatar
What's bad about using the 94 slave cylinder with a 99 nv? that is making you want to return the one? Do you want to return it and use the 98-02.5-02 instead?
2001 ecsb 4x4 some slow stuff
71 f250 crew cab 4x4 cummins swap in progress
crewcabstripper is offline
post #3 of 9 (permalink) Old 03-20-2012, 10:01 PM Thread Starter
The 94 master cylinder and 99 slave is making my clutch pedal where i barely have to push in like maybe 1 1/2 inch to shift gears or take ff. the 94 slave i got to use wont fit the 99 line i have. Also the 99 slave cylinder is way smaller than te 94 As far in total size
post #4 of 9 (permalink) Old 03-20-2012, 10:13 PM
Sounds like you just need the 99 master cylinder to complete the whole hydraulic system to be the newer style nv trans. so the 94 slave is all around smaller? Shorter push rod and slave body?
post #5 of 9 (permalink) Old 03-20-2012, 10:24 PM Thread Starter
The tranny isnt any different from 94 just wondering what i need to do the hydraulics are the only difference
post #6 of 9 (permalink) Old 03-20-2012, 10:26 PM Thread Starter
Like the 94 is a 1" bore and the 99 is like a 3/4" bore. Which makes a difference in pressure and force.
post #7 of 9 (permalink) Old 03-20-2012, 10:30 PM
There is a difference between the 94-98 and 98.5-02 nv transmissions main thing is the newer ones have a short throw shift pattern I would return the 94 slave cylinder and get a 98.5-02 master cylinder and use the 99 slave cylinder line and master you should be set then
post #8 of 9 (permalink) Old 03-20-2012, 10:35 PM Thread Starter
I have it in the shop, the only reason i didnt use it is because the rods that connect to the master cylinder are different lengths and how do i remove the rods because there is little keepers that when u push the rod through it keeps it in the master cylinder
post #9 of 9 (permalink) Old 03-20-2012, 10:42 PM
Sounds like its just the master cylinder / rod length giving you trouble Can you adjust the linkage at the pedal so it takes more pedal travel to fully compress the rod in the master cylinder? If not you might be able to interchange the master cylinder rods I can't say for sure if you can though haven't messed with the older ones
