Auto to 5spd swap speedometer problem - Dodge Cummins Diesel Forum
post #1 of 6 (permalink) Old 03-19-2012, 07:24 PM Thread Starter
cummins12v's Avatar
I I'm in the process of an auto to 5spd swap and
The swap came out of a 2001 dodge cummins with the 241hd transfer case
And the speedometer plug on mine has no were to plug in
On the newer transfer case is there some type of after market speedometer I can hook up or even a way to make this 241hd transfercase work on my 1995 12 valve
96 dually .....runs..... 95 single...trannyless
cummins12v is offline
post #2 of 6 (permalink) Old 03-19-2012, 08:16 PM
DM1970's Avatar
Cant use your transfer case? I'm pretty sure that's the only route but I am sure someone more knowledgeable will confirm or deny that.
1995 Ram 2500 12V NV4500 4x4
DM1970 is offline
post #3 of 6 (permalink) Old 03-22-2012, 09:14 PM Thread Starter
cummins12v's Avatar
To the top
post #4 of 6 (permalink) Old 03-22-2012, 09:20 PM
GAmes's Avatar
iTrader Score: 7 reviews
If you have rear wheel ABS it is not a problem. Go to post #11
https://www.cumminsforum.com/forum/94...ed-sensor.html
Once you have the Dakota digital installed borrow a GPS from someone and calibrate it. I have nearly 140k miles on mine so far, no problems.
97 3500, 2 WD, G56, slightly bombed, 1.3 million miles with un-additized diesel fuel. Started the second million on 8/24/13
GAmes is offline
post #5 of 6 (permalink) Old 03-22-2012, 09:21 PM
Not sure what you're going to do about the stock speedo.
'98 and newer has an electronic speedo, older has a gear that spins in the t-case.
I'm certain it would take a different PCM to make the stock dash speedo work but then you'd probably have a whole new set of problems.
Bill
'95 2500 4wd auto
'95 3500 5 speed heavy hauler
Stock for one day
illflem is offline
post #6 of 6 (permalink) Old 03-23-2012, 09:49 PM
GAmes's Avatar
Please post your final fix. A lot of whiners are complaining that the search feature doesn't give them answers. Thanks.
GAmes is offline
