Lock up switch questions - Dodge Cummins Diesel Forum
post #1 of 8 (permalink) Old 03-19-2012, 06:11 PM Thread Starter
So I figured I'd give it a whirl, and installed one today. It functions. But it shifts so quickly from 2 to 3 like less than a second.
Definitly too quick. I didn't try getting on the skinny pedal to see if that would delay it...
Any experience out there?
I basicly want it for towing steep short hills we have here.
Thanks!
97 3500, single wheels and m103a bed. 4x4 Jasper tranny w/ Goerend VB , single TC and pan. isspro Gauges. 1993 GMC/zuzu4000 dumper, JD790 lots of attachments.
Axtell3 is offline
post #2 of 8 (permalink) Old 03-19-2012, 07:10 PM
Motorboat's Avatar
The lock up switch should not effect the shift pattern.
'97 3500. 4X4 3:55s, built auto, vb and triple disc tc w/lockup. Boost, trans, pyro and F/P. Silicone hoses and boots. Icebox intake, 4" Diamondeye. 10 plate, 330s, 60# springs, 4GSK, Pacbrake. Mag trans and diff covers. Firestone Bags and 51 Gal. transfer tank.
Motorboat is offline
post #3 of 8 (permalink) Old 03-19-2012, 07:36 PM Thread Starter
Ididn't think it would either.
Axtell3 is offline
post #4 of 8 (permalink) Old 03-19-2012, 08:02 PM
zthatzmanz28's Avatar
I removed my lock up switch when I did the POTS in place of the TPS. With OD off I cam lock at 30 MPH and it shifts normal.
1998 2500 4X4 CTD QCLB 3 inch lift-- Stablizer Bar-Tork Tek OFV-MAXX links-KDP TABBED-Luke's Link & Bushing POTS LMC dash #10 fuel plate AFC ISSPRO fuel- boost-2K* PYRO BHAF Posi-Loc Larry B Solenoid & relay rebuilt 47re low stall TC
zthatzmanz28 is offline
post #5 of 8 (permalink) Old 03-19-2012, 09:09 PM Thread Starter
I was looking for lock up in 2nd. I guess I can shift to 2nd then lock it for the steep stuff. I did the POT a month or so ago, but I think it crapped out on me. I had to hook up the tps again. Maybe the radioshack ones aren't that great?
Axtell3 is offline
post #6 of 8 (permalink) Old 03-20-2012, 12:07 AM
68bullittbuilder's Avatar
On a stock valve body you can't lockup in 2nd, just 3rd and o/d. With certain shift kits you will be able to make it lock in 2nd. I got my pot from radio shack, no problems with the pot, just with the pcm connections. Just don't try locked shifts, you'll regret it.
1997 CCLB 330K and counting. 5" DiamondEye, BHAF,SuperB, 4K GSK, 60lb springs AFC mods, AFC LIVE, 5x12's, ISSPRO EV2's, Revmax Trip Disc Converter w/ low stall stator, Built Auto...Sure there's more
68bullittbuilder is offline
post #7 of 8 (permalink) Old 03-20-2012, 01:16 AM
12valveterror's Avatar
iTrader Score: 9 reviews
probably a TPS/wiring issue, and a stock valvebody wont lockup in 2nd, most modified ones will and some will lock up in 1st, like mine does
Engine: Mahle "Marine" Pistons, Balanced Rotating Assembly, ECD Cam, O-Ringed Block, Ported/O-Ringed Head, 3 Angle Valve Job, ATI SuperDamper
Fuel/Air: 475cc P-Pump, 5x.014's, Airdog 150, BW 66/68/14
12valveterror is offline
post #8 of 8 (permalink) Old 03-20-2012, 07:19 PM Thread Starter
well mine is. I had the tranny replaced last may with a GASP Jasper. They claim 21 upgrades over stock. good luck getting the list of upgrades though.
I do plan on a valve body and single low stall tc... figuring out which is my quandry.
Axtell3 is offline
