Ready to Tackle Timing Case. What Pullers Needed? - Dodge Cummins Diesel Forum
post #1 of 5 (permalink) Old 03-19-2012, 10:15 AM Thread Starter
my69camaro1's Avatar
iTrader Score: 4 reviews
I'm going to start taking the truck apart tonight so I can replace the cracked timing case.. I plan on pulling the cam gear off as that seems like a far better option for me to handle. We have mulitple types of pullers here at work and I plan to borrow a bearing heater to put the gear back on..
Question, what kind of puller should I use? Something that bolts to the gear, or something with jaws that grab around the gear? I dont want to damage it. Is much force needed to pull it off, how tight of a fit?
Thanks
eta : 1995 12v
my69camaro1 is offline
post #2 of 5 (permalink) Old 03-19-2012, 05:06 PM
iTrader Score: 7 reviews
there are no bolt holes in the cam gear you will need a jaw type puller and you can use a steeringwheel puller for the pump gear if you dont have a pump gear puller
twisted_diesel is offline
post #3 of 5 (permalink) Old 03-19-2012, 05:13 PM
Smourj21's Avatar
How are you going to press it back on??
02 QCSB 6 Speed|215 P-Pump 600cc|Balanced & Blueprinted|Billet Rods||Steed Speed|.084 Lines/Tubes|AirDog200|Hamilton 194/220|Oversized Intake Valves|Ported Head|Side Draft Intake|Spearco IC|Valair Tripple Disk|4.88 Gears|Truetracs|On 35's| Fuel and air Undecided
Smourj21 is offline
post #4 of 5 (permalink) Old 03-19-2012, 06:06 PM Thread Starter
Sounds good, I know we have many different sized jawed/hooked pullers so I'll grab several.
I'm assuming from what i've read I just have to heat the gear up. I use the bearing heaters at work daily and thats nice and easy, no torch or oven bs. Then slide it onto the shaft no issues.
- 2012 ST 3500 SRW 4x4 G56 19,900mi H&S BM, ARP625, 5in pipe, Carli 3in, BMFs, toyo 35s, II 100s, Steed Speed, BW 472.
- 2018 Single Cab SLT 2500 Hot Rod.
post #5 of 5 (permalink) Old 03-19-2012, 07:32 PM
Three jaw puller works.
Make sure to remove the lift pump and use a bar to hold the cam when slipping the gear back on or you might have to pull the engine.
Instructions> https://www.cumminsforum.com/forum/2349170-post2.html
Bill
'95 2500 4wd auto
'95 3500 5 speed heavy hauler
Stock for one day
illflem is offline
