low rpm sputter, and unstable idle - Dodge Cummins Diesel Forum
post #1 of 4 (permalink) Old 03-18-2012, 09:37 PM Thread Starter
hey,
my 12v is unstable at idle, not like the truck shakes, it just sounds like it misses on one cylinder every 1.5 seconds. and when its under a load, like taking off in second or shifting to third, around 1000 to 1400 rpm it sputters, like its starving for fuel, but after that it hauls pretty good and leaves quite a bit of black after 1500rpm, i think its supposed to smoke black more but im not sure. it sputters in every gear, even first but its hardly noticable cuz its not a big load.
i did hook up a fuel pressure gauge, but i don't have a needle valve yet and can't even get one here, believe it or not, so im gonna order one. but would the fuel pressure be a lot different running in idle than under load? fuel volume problem?
or do i have a worn out injector? the truck had been sitting for 1.5 years. i did not blow out any lines yet, but i did put new diesel in cleaned the tank and pulled injectors, cleaned them, new ofv and lift pump.
thanks
1992 Forge F350 CCLB - Cummins 24 valve, HP Torque Convertor, Factory Exhaust Brake, HX35
1994 12v 5.9 2500 ram 180hp - 5-speed NV4500, #0 plate, AFC/startwheel forward, 16.5, 5x0.12 DAP, 181DV, 60#, 4000gsk, GlowShift - Pyro/FP/Boost and turbo coming later
rickmeima is offline
post #2 of 4 (permalink) Old 03-19-2012, 12:42 PM
just had the same thing on my conversion. Injectors sat for a couple years and had to take them to an injector shop and have them popped. put them into the truck about an hour ago and it runs a lot better.
milesengineer is offline
post #3 of 4 (permalink) Old 03-20-2012, 02:13 AM Thread Starter
Is there any way I can make a pop tester for a Cummins? There's no one in my town that does, live up north in Canada so
post #4 of 4 (permalink) Old 03-20-2012, 12:30 PM
You sure there's no one?
Any heavy equipment or tractor shop can pop them.
Bill
'95 2500 4wd auto
'95 3500 5 speed heavy hauler
Stock for one day
illflem is offline
