Brand new clutch slipping the same as old clutch - Dodge Cummins Diesel Forum
post #1 of 20 (permalink) Old 03-17-2012, 11:15 PM Thread Starter
95cummins5.9's Avatar
my buddy and i replaced his clutch in his 96 today, it was slipping 4th and 5th on heavy accel. put a brand new clutch in it today and its doing the same thing exactly. and the old clutch didn't look bad in my book.... i know theres break in bla bla but it shuldn't do the same thing??? is there any way the slave cylinder or the slave cylinder rod is too long. ... truck is stock old man driven. stock napa luk clutch ... happy st. pattys day and thinks for your help !!!
95 RCLB 5 speed 4x4 440,000. plate slid, afc mods, DAP 230's BHAF 18*
97 ECLB 5 speed 4x4 370,000. 100 plate, afc mods and tuned, natural aspiration lol currently, smokem 5x14s, 7mm d.v.,20*,BHAF
95cummins5.9 is offline
post #2 of 20 (permalink) Old 03-17-2012, 11:18 PM
pic_jon's Avatar
Is the truck completely stock?
Was the flywheel machined?
97 12v 2wd project: Dual-Fed 913 by Seth | 148* 7x.010" | 351cw/475/92/1.1 | Valair DD
pic_jon is offline
post #3 of 20 (permalink) Old 03-17-2012, 11:24 PM Thread Starter
mostly stock... brand new flywheel....nothing crazy on mods with the truck(no gauges) slid afc, plate in the middle, tuned for no smoke old man style
post #4 of 20 (permalink) Old 03-17-2012, 11:48 PM
pic_jon's Avatar
I'd never expect a stock clutch to hold up against a slid plate & semi-tuned afc. Especially during heavy 5th gear acceleration.
pic_jon is offline
post #5 of 20 (permalink) Old 03-18-2012, 01:08 AM Thread Starter
driving the truck more tonight it seems that the clutch pedal lets off at the top of the throw or late. NOT at the floor board. I did some searches and seen where the slave cylinder itself does not let the throw out bearing to disengage completely. Could this be my problem? Should i try slightly loosing the slave away from the bellhousing to see if it would make a difference?? i have seen a stock clutch from napa just like this one take more than this, and it doesn't make sense that old clutch was doing the same exact thing??????
post #6 of 20 (permalink) Old 03-18-2012, 08:45 AM Thread Starter
to the top
post #7 of 20 (permalink) Old 03-18-2012, 10:56 AM
renopker's Avatar
The OEM clutch will take more power then that motor is making, Why would the slave cyl. rod be to long? Unbolt the cylinder and see how much the fork free play is.
I love pigs, they turn vegetables in to Bacon
renopker is offline
post #8 of 20 (permalink) Old 03-18-2012, 12:13 PM Thread Starter
there is no free play in the rod.. the clutch pedal feels like a 2 year old could push it to the floor easily! thanks ron keep em coming!
post #9 of 20 (permalink) Old 03-18-2012, 12:19 PM
renopker's Avatar
No free play at the throwout fork ? If there is NO fp at the fork the problem is in side.
renopker is offline
post #10 of 20 (permalink) Old 03-18-2012, 12:30 PM Thread Starter
there is free play with the fork itself... the rod from the slave just goes in harder than any of my five speeds... what could be the issue inside of it?? could i try putting some washers between the slave and bell housing to see if it the slave itself not releasing enough???
post #11 of 20 (permalink) Old 03-18-2012, 12:48 PM Thread Starter
just for the record on stock clutch strength. i had a stock clutch the same style that i ripped the center out of before i ever got it to slip... so i agree that this one shouldn't be slipping with the mods mentioned..
post #12 of 20 (permalink) Old 03-18-2012, 01:17 PM
renopker's Avatar
OK so you have free play at the fork. Then its not in the bell housing your left with the slave or the master try the washers but it sounds like one of the two are not returning all the way back.
renopker is offline
The Following User Says Thank You to renopker For This Useful Post:
Shainer (03-18-2012)
