96 12V Oil Pressure - Dodge Cummins Diesel Forum
post #1 of 9 (permalink) Old 05-30-2006, 03:53 PM Thread Starter
Unhappy 96 12V Oil Pressure
I have a 96 cummins (140K) and the oil pressure guage will drop to nothing and the truck quits. Seems to be fine while rolling down the road. mostly does it in reverse at idle. Is the sending unit the problem or is there a real chance the pump is going bad?
randyrusson is offline
post #2 of 9 (permalink) Old 05-30-2006, 04:20 PM
First of all, WELCOME!! Sorry to hear about your truck, however, your problems may be simple to fix. It sounds like you have an auto tranny. (reason to fill out your sig) Does it idle at the right RPM? It should idle at 750 RPM with the tranny in gear (auto) and with the A/C on. If it is idling to slow it will do just exactly what yours is doing. Look HERE for instructions. You may also have a sending unit dying too. That is also a very common problem. Look HERE for a drawing of your engine. The oil pressure sending unit is right behind the power steering pump.
Tom
p.s. I moved it to the 12v forums for you.
Tom05 is offline
post #3 of 9 (permalink) Old 07-04-2006, 01:31 AM
how common is the oil sender? i had one in my 95 go from 50 psi to zero while on the h'way, but my 98 gives me a check guages light when i come to a sudden stop, the pressure goes to zero for about five secs. the only problem is the first time it happens, it scares the crap out of you. oil and filter was changed two weeks ago, oil is right at the mark, if i remember, the sender was about $20.00 at the dodge boys. any ideas?
SEMPERGUY is offline
post #4 of 9 (permalink) Old 07-04-2006, 01:35 AM
Yes, Tom is correct. It sounds very much like your idle is too low AND you need a new pressure sender (from Cummins).
Idle Adjustment:
http://www.cumminsdatabase.com/read.php?id=34
http://www.cumminsdatabase.com/read.php?id=36
http://www.dodgeram.org/tech/dsl/adj...d_Gen-Idle.htm
Also, you might want to change the fuel filter and clean/replace the prefilter:
http://www.dodgeram.org/tech/dsl/fil...uel_filter.htm
http://www.cumminsdatabase.com/read.php?id=137
Dr. Evil is offline
post #5 of 9 (permalink) Old 07-04-2006, 01:36 AM
Very common problem to have the senders die - but dude, theres NOTHING at a Dodge Dealer that is $20 (not even the oil filters)
Dr. Evil is offline
post #6 of 9 (permalink) Old 07-04-2006, 01:44 AM
I Think That Is What They Charged Dealer Net, But Is The Cummins Unit A Better Deal? I'm Only 20 Minutes From Cummins Northeast.
post #7 of 9 (permalink) Old 07-04-2006, 11:25 AM
When I got mine it was about $42 from Cummins IF i rememeber correctly.
Tom05 is offline
post #8 of 9 (permalink) Old 07-10-2006, 01:32 PM Thread Starter
Thanks guys for the help! The Idle was adjusted and the tranny problem was solved. Ordered a new sending unit.
Thanks Again!
post #9 of 9 (permalink) Old 07-10-2006, 09:53 PM
You are welcome Randy. That is what we are all here for.
Tom
Tom05 is offline
