Horrible Oil leak - Dodge Cummins Diesel Forum
post #1 of 7 (permalink) Old 02-10-2012, 03:33 PM Thread Starter
NACR_clifford's Avatar
Horrible Oil leak
Hey guys, I have a bad oil leak by number 5 on the exhaust manifold, thke rocker box is clean and from my understanding there is no oil on that side. Its from the head down. Thanks and any advice is appreciated
NACR_clifford is offline
post #2 of 7 (permalink) Old 02-10-2012, 03:40 PM
12valvedriver's Avatar
Do you mean its running on the the exhaust manifold? Probably a valve cover on #5 or #6. Check those first
'90-Getrag 360, mostly stock
'97-NV4500, Kinda fast
'17-G56, all stock
12valvedriver is offline
post #3 of 7 (permalink) Old 02-10-2012, 08:24 PM Thread Starter
It isnt leaking there
post #4 of 7 (permalink) Old 02-10-2012, 08:41 PM
If it for sure isn't from the valve cover then about the only other thing it could be is a head gasket or cracked head.
You should have oil in your coolant then also.
Bill
'95 2500 4wd auto
'95 3500 5 speed heavy hauler
Stock for one day
illflem is offline
post #5 of 7 (permalink) Old 03-21-2012, 01:29 AM
Nate Gunn's Avatar
oil out tailpipe
I have the same problem on a 95 12v bad oil leak out he exhaust. No oil in coolant, no coolant in oil?? Turbo just replaced. cracked head? or gasket? sounds like it is running on 5.....? I'll check compression next.
95,4x4,12v,5 speed w/SB13" single,4" ex,BHAF,twin ram,Fass,Propane,VEG,225K, KDP survivior
[/CENTER]
Nate Gunn is offline
post #6 of 7 (permalink) Old 03-21-2012, 09:33 AM Thread Starter
On mine it turned out to be the gasket, I put a new oem one stock thickness an still did it, then put a fifty thousandths one an fixed it, there never was coolant in oil but slowly oil turned up.in coolant....dounle check everything first and good luck man
post #7 of 7 (permalink) Old 03-21-2012, 09:49 AM
cummins4x493's Avatar
my valve cover has everything covered, the injectors and the little holes next to them are filled with oil. that causes my oil leak
1994 dodge cummins 4x4 std cab sony xplod amped at 300 watts 8 in sub coming auto 200k miles and going up everyday
cummins4x493 is offline
