speedometer and overdrive not working - Dodge Cummins Diesel Forum
post #1 of 7 (permalink) Old 08-03-2011, 10:19 PM Thread Starter
derez's Avatar
ok i need some help here. my father blew up my transfer case on my 95. i got another out of a 94 and installed it. after the install my speedometer doesnt work and the truck doesnt shift into overdrive. i put a new speed sensor in and checked the voltage going to it. it checked out fine. there is no ABS light or nothing. any ideas on what to check next. thank you ahead of time.
2005 qclb 2500 g56, sliverbullet silencer ring mia, afe, 2nd gen manifold, smarty s06, fass 150, duel cp3, cfm+, studded, injectors, sb dd, straight exhaust 702 hp
1995 sclb 2500 stock for now. new prodject.
derez is offline
post #2 of 7 (permalink) Old 08-03-2011, 10:20 PM
GAmes's Avatar
iTrader Score: 7 reviews
When you installed it did you position it's clock angle in accordance with the number of teeth on the gear?
97 3500, 2 WD, G56, slightly bombed, 1.3 million miles with un-additized diesel fuel. Started the second million on 8/24/13
GAmes is offline
post #3 of 7 (permalink) Old 08-03-2011, 11:23 PM Thread Starter
derez's Avatar
yes i did. i even adjusted it alittle either way to see if it was off alittle.
derez is offline
post #4 of 7 (permalink) Old 08-05-2011, 03:54 PM Thread Starter
derez's Avatar
any other ideas
derez is offline
post #5 of 7 (permalink) Old 08-08-2011, 02:54 PM Thread Starter
derez's Avatar
someone else has to have other ideas or guesses
derez is offline
post #6 of 7 (permalink) Old 08-08-2011, 03:21 PM
CREED's Avatar
Alternator still charging?
CREED is offline
post #7 of 7 (permalink) Old 08-08-2011, 11:55 PM Thread Starter
derez's Avatar
it seems like it
derez is offline
