47RH to NV4500 Swap 94 RCLB 4x4 - Dodge Cummins Diesel Forum
post #1 of 5 (permalink) Old 06-03-2011, 11:03 PM Thread Starter
suckindiesel's Avatar
well i'm new to the forum but I thought I would try to lend my spin on the 47rh swap. Mechanically the swap from the 47rh to the nv4500 is straight forward no real modifications needed if you can get a wrecked truck. You need everything behind the engine including drive lines the front is a must have. The rear line will more than likely need to be lengthened and that's about it. As far as small differences between auto vs stick parts are larger crossmember on manuals and mounts for tranny are different. The manual is beefier, the transfer linkage is shorter and the shifter has a smaller footprint on the side of the trans. so having the manual 4x4 shifter and linkage makes it go a little faster. I was lucky enough to obtain all the parts needed for the swap (used) before I began so I was able to compare everything side by side all were stock parts. After hunting for about 18 months!! Nothing was purchased NEW except nss and slave, clutch looked new so i just resurfaced the flywheel.
So the wiring, what a joke Now my truck has the old single port 60 pin PCM connection on the passenger side inner fender well. I'm not sure about newer models. What I did was REMOVE the jumper on nss switch connection and just plugged in my nss switch from the master clutch cylinder. Next cut the 3 way flat connector for the nss/reverse factory 47rh switch. True the outside pair are for the reverse lights which I just put on a toggle never know when you'll need em. The middle wire which will be black with a white tracer is your engine start relay nss sense which will be in #30 cavity in the 60 pin connector. I just taped the trans side of this wire and went from the PCM side with a wire tap. It is possible to pull this wire out of the loom (trans side) completely from the engine side just be careful. Ground that wire only if the truck won't start without it grounded. Everything worked like a champ. Any questions ask now while it's fresh The old 47 with complete auto swap may be for sale any takers?
suckindiesel is offline
post #2 of 5 (permalink) Old 06-15-2011, 01:51 AM
CrazyktmMatt's Avatar
How much are you asking?
'90 cummins 47rh. Maxed pump no ic.42 psi in valet mode. In need of water meth for new found bigger egt problems. Need to find a set of 3.54 geared axles.
'92 flatbed HE351 and a spring device of some sort and a lame 518 the steals power.
CrazyktmMatt is offline
post #3 of 5 (permalink) Old 06-15-2011, 03:06 AM Thread Starter
well do you want the whole swap: trans, lines, cooler, pedal etc... or just parts let me know what you want
1994 12v 2500HD 4x4 RCLB 1.5" level, #6 plate, 47RH to NV4500 NP241DHD, SB 13" Clutch
, DT Track Fix, DT Steer Brace, 260k and still strong
post #4 of 5 (permalink) Old 06-15-2011, 11:31 AM
sdiesel's Avatar
just the trans core interests me. mot even the torque converter
where are you located?
1994 3500 dually build date:12-93 new:trans, t case, cage long arm suspension sulastics, pre filter/heater MIA / HX35/40 4/5inch exh more much more
sdiesel is offline
post #5 of 5 (permalink) Old 06-15-2011, 12:33 PM Thread Starter
Im in nevada city,ca ill take 900 for the trans alone. It is in good condition and working ill try to add a pic or 2.
The Following User Says Thank You to suckindiesel For This Useful Post:
barkey24 (11-08-2012)
