Driveshaft noise - Dodge Cummins Diesel Forum
post #1 of 5 (permalink) Old 03-16-2011, 11:21 PM Thread Starter
Driveshaft noise
I'm getting a lot of noise in the driveshaft on my truck, especially when accelerating in 3rd and 4th gear. U-joints appear to be tight, pinion bearings tight. The only thing I am questioning is that I have the 2 piece drive shaft, and I was wondering if the carrier rubber was weak would cause it to do this. Its a tinging / rattling in 3rd 4th or 5th under load or toque. Anyone else experience this?
1997 Dodge 2500 3/4 ton ext. cab 4x4 5sp., Dana 80 rear, 3:55 gears, Dual 5 inch stacks, 116,000 miles
farmboy1989 is offline
post #2 of 5 (permalink) Old 03-25-2011, 02:19 AM
yes this is a very comman problem just get under the truck grap the drive shaft at the u joints behind the carrier and move it up and down left and right if there is any movement its in need of a new one i actually just bought one for my truck it was 36.00 at napa but i seem to have the wrong one its wider then the one on my truck i called several stores and they all say its the right one for my truck well the one they gave me is like 7 inches wide and mine is only 5 hmmmmm good luck
99 rclb 4x4 nv4500 96k non 53 150 jammers, ejwa hot unlock, s/b intake, afe itake horn, 150 raptor big line + drawstraw, 5" full 8" tip
720tobe is offline
post #3 of 5 (permalink) Old 05-23-2011, 01:09 AM Thread Starter
Well a new front u joint, new carrier bearing, and lots of looking later, its still making noise. 4th gear is the worst. The only place I can find anything questionable is the bushing in the tailshaft housing looks a little rough, although the output bearing in the transfer case was ok. There is some a small amount of front to back movement on the output shaft in the transfer case. I am assuming that is just snap ring to snap ring though. Anyone have any ideas? Put it up on stands and run it and no noise, but when i put the brakes on to give it a little load it got noisy. I'm hoping its the output shaft bushing allowing the the driveshaft to work on the splines and a new one will fix it.
post #4 of 5 (permalink) Old 06-16-2011, 09:20 PM
CorneliusRox's Avatar
I wish you had a solution for this because this exact thing just started happening to me... All u-joints are pretty new too...
Corey - BSME --- 97 12V Michigan Rust Bucket
CorneliusRox is offline
post #5 of 5 (permalink) Old 04-06-2019, 03:26 PM
Hi, i am having the same exact issue, we’re you able to find the solution? Your feedback is greatly appreciated
Josh
JoshuaWolf is offline
