Ticking noise under hard acceleration - Dodge Cummins Diesel Forum
post #1 of 8 (permalink) Old 03-02-2020, 09:50 PM Thread Starter
Thumbs down Ticking noise under hard acceleration
Ole girl has a loud ticking/tapping noise
gets louder and taps progressively with rpms
starts under hard acceleration/ high boost pressures
sounds right in front of me as im driving
i never heard the tapping before I put new injectors in
the 5in exhaust and intake and boost elbow
but I wasn't hitting those boost pressures
any idea's? shes got a new lift pump.
97 12 valve, 280k miles, 120 hp injectors, cut fuel plate, 5in straight pipe, afe air intake, boost elbow, firepunk trans
sweeney813 is offline
post #2 of 8 (permalink) Old 03-02-2020, 10:54 PM
pa coal roller's Avatar
Valves or maybe one of the injectors isn't right
2012 cc dually 6speed, mini max, cooler delete, h&s intake horn, boost tube,5ich pipe,gdp big line kit Amsoil dealer since 2006
1996 12v 430000 miles. Built trans. 62mm hx 35 90hp injectors
pa coal roller is offline
post #3 of 8 (permalink) Old 03-03-2020, 12:49 AM
McDivittD's Avatar
Could be an exhuast leak
98.5 24 Valve Quad Cab Long Box 5 Speed 4x4
McDivittD is offline
post #4 of 8 (permalink) Old 03-03-2020, 11:39 AM
If yur truck is an auto trans, check the flex plate. It may be cracked. When cracked they will make noise under acceleration.
96 Ram 2500. 5.9 Auto, 4x4. Banks Air, split intake, 4" exhaust, HD billet torque convertor, gauges. Fuel and air tweaked a bit.
Tommygunner is online now
post #5 of 8 (permalink) Old 03-23-2020, 01:18 AM Thread Starter
The injectors checkout, the flex plate is brand new and rates for 800hp. It’s gotta be valves. I’m going to get a valve adjustment and check back in
post #6 of 8 (permalink) Old 03-23-2020, 02:39 AM
Probably just the normal sound of the injection pump and injectors at high fueling. Mine does the same thing and I've never worried. Did it before and after a valve adjustment. Have you ever heard one of these pumps running on a stand? I think there's a video of one of them.
'97 3500 4x4 CC DRW, 4.10, Banks PP, BD tc, vb, eb, 60# springs, Torqloc, gauges, Weatherguard, B&W...
'92 CC W350 DRW sold '92 CC D350 DRW sold '12 Laramie CC 3500 4x4 SRW sold
brownbear is online now
post #7 of 8 (permalink) Old 03-23-2020, 07:15 AM
alanack6795's Avatar
My lift pump is pretty noisy sometimes.
alanack6795 is online now
post #8 of 8 (permalink) Old 03-26-2020, 01:58 AM
Bad injector? Loosen the fuel lines at the injectors one at a time with the engine running. if the noise goes away on one you have a bad injector.
1995 RAM 2500 Club Cab Laramie SLT 2 W/D 5.9 P-Pump w/ NV4500 3.54 Dana 80. Nearly stock. Timed @ 15.5* Currently 318,000 miles and counting.
dd453ford is offline
