Seriously thinking about one of these... - Dodge Cummins Diesel Forum
 1Likes
post #1 of 20 (permalink) Old 02-11-2020, 09:32 PM Thread Starter
It's not cheap.
https://www.caconversions.com/
'97 3500 4x4 CC DRW, 4.10, Banks PP, BD tc, vb, eb, 60# springs, Torqloc, gauges, Weatherguard, B&W...
'92 CC W350 DRW sold '92 CC D350 DRW sold '12 Laramie CC 3500 4x4 SRW sold
brownbear is offline
post #2 of 20 (permalink) Old 02-11-2020, 10:15 PM
GAmes's Avatar
iTrader Score: 7 reviews
The Suburban puling the big truck out is so hokey I wouldn't do business with them.
97 3500, 2 WD, G56, slightly bombed, 1.3 million miles with un-additized diesel fuel. Started the second million on 8/24/13
GAmes is offline
post #3 of 20 (permalink) Old 02-11-2020, 10:47 PM Thread Starter
Yeah, it's hokey but that doesn't bother me at all. Their products are top notch. Years ago this was something that was a pipe dream and now they have a bolt on kit for guys like me who want 6 gears and the best light duty tranny out there. Not only would I get more gears, the 2nd overdrive is .614:1 instead of my .69:1. That will drop my rpm by 250 on long trips. That's huge considering I have 4.10s. I'll probably gain 2-3 mpg (unloaded).
The biggest issue for me is finding a shop where I can tear my truck apart. I want to do this as well as replace the oil pan, put in new upper and lower ball joints, and do a few other things. Otherwise, I'd probably just buy a brand new one. I was looking, but I don't like the prices on new. They've just gotten extreme.
post #4 of 20 (permalink) Old 02-11-2020, 11:05 PM
alanack6795's Avatar
I would recommend a g56 or nv5600 but the overdrive probably isnt as good.
I love my g56 but using the clutch while shifting was tough to get used too. Now I love it, especially when towing.
The alison is great transmission for work trucks that tow and haul. we have a lot of old trucks with them and they rarely give us problems.
Its a great conversion starter too 😎
alanack6795 is offline
post #5 of 20 (permalink) Old 02-11-2020, 11:16 PM Thread Starter
Every time I drove the Duramax with the Allison I just loved the tranny. I'm thinking that's the ticket for my truck. I've really been hemming and hawing this winter on whether or not to get a new rig. I even looked at some gently used 4th gens, etc. I never found anything I liked for the price, new or used.
There was a 2007 with a G56 with 100,000 miles, really clean, but the guy wanted over $30k for it and I just couldn't see paying that much for a truck with over 100k miles. No way. Every time I look at something I like my old truck better, I just want a different transmission. If I was a flatlander then the 47re would be fine, but I spend a ton of time in the mountains, oftentimes hauling heavy weight.
I'm thinking of doing the conversion and also putting a Norstar flatbed on the truck. I've needed it with the work I've been doing. It would come in really handy. That will also give me the opportunity to steam clean everything from the cab back, then paint the frame before I put the bed on.
post #6 of 20 (permalink) Old 02-11-2020, 11:29 PM
Flat beds are nice, they do tend to raise the floor height vs the bed, which is a little annoying.
When my replacement bed rusts out again i will throw a Bradford built on there or something.
post #7 of 20 (permalink) Old 02-12-2020, 12:35 AM
Fire god's Avatar
Typical and expected. Bravo!
95 3500 auto, bhaf, 4k, kdp, gauges, air bags, fuel htr delete, 33"s, dually spacers, 4.10 lim slip, 2" level, silicone hoses, tps delete, tcc switch
Fire god is offline
post #8 of 20 (permalink) Old 02-14-2020, 02:51 AM
I looked at that but it required many adaptors. I went with the 68rfe conversion and ended up with the same amount of gears but with a better gear spread. I now have 6 speeds with a manual override of 1-6 and lock-up in in 3rd through 6th in TH and in 4th through 6th in regular with 6th lock-out if needed. Couldn't be happier. It is almost a bolt up/in conversion.
Good luck.
'96' CCLB SLT, 4x4, 12V, (68RFE, Rev Max TC, VB work), KDP, '98' Spt. Hdlt.,Pwr Tow Mir., gauges, 16*, 4K GSK, 60#'s, TT AOFV, 3pc Ex., PDD 5x12's, HE351cw, AFCLive, TB 4" Ex., BHAF, 265x75x16's, Str. Bx Brace, HD Str., Red-Head, Air Bag's
63willys is offline
post #9 of 20 (permalink) Old 02-14-2020, 08:13 PM Thread Starter
Good luck.
Curious regarding your conversion. What specialty parts did you need? Where did you get the electronics, etc.?
post #10 of 20 (permalink) Old 02-14-2020, 08:58 PM
Loud Pedal's Avatar
I think of the movie Bambi when you do this....
98-4x4 5spd
Loud Pedal is offline
post #11 of 20 (permalink) Old 02-14-2020, 09:13 PM
Kmehr's Avatar
I hope that if you do this allison, you post lots of photos. I'm a stick guy, but I've been very impressed with every allison I've driven. I sometimes find myself reaching for 7th gear on my nv5600.
1984 Dodge CCSB P-pump NV4500- SOLD
2005 QCSB NV5600, SouthBend OKHD, CFM+, Jake brake, Thuren 3in, Vulcan w/ CAT UHE 416-1225, CTS2, HPTuners by Optimal Welding, BBI stage 1, II bag of parts
Kmehr is offline
post #12 of 20 (permalink) Old 02-14-2020, 10:33 PM
Fire god's Avatar
A sidekick would...
Fire god is offline
