Exhaust manifold; what’s it telling me? - Dodge Cummins Diesel Forum
post #1 of 15 (permalink) Old 01-26-2020, 05:20 PM Thread Starter
ekvhekvh's Avatar
Pic says it all. What’s it telling me? Thanks in advance.
96 Ram 2500 4x4 automatic. Engine number: ??? Missing.
ekvhekvh is offline
post #2 of 15 (permalink) Old 01-26-2020, 05:31 PM
rubberfish's Avatar
My last engine did that same thing, and IIRC my mechanic at the time told me I
was just going to have to accept the fact that I had the cutest little exhaust leak.
Bob
'92 GMCummins with all the usual crap.
rubberfish is offline
post #3 of 15 (permalink) Old 01-26-2020, 07:32 PM
myother4x4isaCJ7's Avatar
Mine did that when it had bad valve stem seals.
Does your truck white or grey smoke? If no then I would ignore the stain.
myother4x4isaCJ7 is offline
post #4 of 15 (permalink) Old 01-27-2020, 12:26 AM Thread Starter
ekvhekvh's Avatar
I have 60lb springs to install. Need some valve seals and a warm place to do it. Bluish when cold, then pretty decent unless I floor it. Smells rich for fifteen minutes after startup.
ekvhekvh is offline
post #5 of 15 (permalink) Old 01-27-2020, 01:08 AM
Fire god's Avatar
When you do the springs use MLS gaskets at the manifold.
95 3500 auto, bhaf, 4k, kdp, gauges, air bags, fuel htr delete, 33"s, dually spacers, 4.10 lim slip, 2" level, silicone hoses, tps delete, tcc switch
Fire god is offline
post #6 of 15 (permalink) Old 01-27-2020, 01:41 AM Thread Starter
ekvhekvh's Avatar
Exhaust manifold?
ekvhekvh is offline
post #7 of 15 (permalink) Old 01-27-2020, 12:07 PM
ofelas.5z's Avatar
Yes; 6 MLS gaskets for the exhaust manifold to head.
3929881 Exhaust Manifold Gasket Set - 1988-98 12v Dodge Cummins
R12 in the summer, Webasto in the winter; cassette tapes & SAE-20078 all year.
ofelas.5z is offline
post #8 of 15 (permalink) Old 01-27-2020, 12:55 PM Thread Starter
ekvhekvh's Avatar
How are the stock bolts going to come out? Best to try hot? Cold? Rub the Buddha belly first?
ekvhekvh is offline
post #9 of 15 (permalink) Old 01-27-2020, 01:55 PM
BFD
BFD's Avatar
My 97 did that when the manifold shrunk and pulled the end up. Try tightening it. that worked for mine but I replaced it anyway. Craig
2012 CCLB 4wd dually, 3.73, 68rfe, Fass, BD IH and E-brake kits. DD and towing machine.
Olde too soon... Schmart too late!
BFD is offline
post #10 of 15 (permalink) Old 01-27-2020, 03:54 PM
Fire god's Avatar
Pb blaster. Soak. Unbolt. Might as well put at least a 3 piece manifold back on.
Fire god is offline
post #11 of 15 (permalink) Old 01-27-2020, 05:29 PM
this is what i did. all bolts came out...but i have 120k on my engine. i did use the cheap gaskets though...didn't know about the MLS stuff.
BJ
95 ECLB 4x4, DSS, HD X-over steering, auto., Hell bent 2.5" lvl, Thuren track bar, tabbed KDP, 4" MBRP, Autometer EGT/Boost/Fuel Pressure, Otherwise all stock.
no_smokn is offline
post #12 of 15 (permalink) Old 01-27-2020, 05:51 PM
On call 24/7
98whitelightnin's Avatar
iTrader Score: 16 reviews
Other than there being 2, instead of 6, are there any differences in these and the cometic brand MLS gaskets? I need to order a set myself
1998 12v, 4x4, Club Cab, Carli, Thuren, BlueTop, Core 4x4, BD Diesel, PDD 5x.012, South Bend
2012 Laramie Longhorn, EFI by Ryan, Carli, Thuren
1995 Dually, Weston's 5x.016, 4k GSK, 5" FloPro, 255/85r16 Toyo M/T, Goerend, ARP, 60# Springs, BW 62/65/14, BW 75/96/1.10, Isspro, Fass 125, BDP Sump, 7mm DV's, 751 HP 1883 FP Torque on NOS
1998 P-Pumped 24v, 4x4, NV4500 swap
98whitelightnin is offline
