Head bolt missing - Dodge Cummins Diesel Forum
 1Likes
post #1 of 14 (permalink) Old 01-24-2020, 02:39 AM Thread Starter
Head bolt missing
I was looking under the hood the other and day and couldnt believe it but i have a whole head bolt missing on exhaust side of cylinder 2.
How might this have happened?
how should i go about inspecting and fixing this?
am i at any danger of blowing a head gasket?
are there any side effects this could cause?
97 12 valve, 280k miles, 120 hp injectors, cut fuel plate, 5in straight pipe, afe air intake, boost elbow, firepunk trans
sweeney813 is offline
post #2 of 14 (permalink) Old 01-24-2020, 04:38 AM
#1 would be to look down the bolt hole to determine if the bolt is MIA, or if it broke off.
1995 RAM 2500 Club Cab Laramie SLT 2 W/D 5.9 P-Pump w/ NV4500 3.54 Dana 80. Nearly stock. Timed @ 15.5* Currently 318,000 miles and counting.
dd453ford is offline
post #3 of 14 (permalink) Old 01-24-2020, 08:10 AM
Stox225's Avatar
Head bolt missing
The bolt probably got corroded and its strength was compromised.
I had an ARP stud break off in the exact spot. No clue ow long it was like that before I noticed. It took me another 2 months to get the correct replacement stud. My timing it set at 21*. Never blew the HG. That being said, I was VERY light on the throttle for those 2 months.
24hrsparkey likes this.
1997 Cummins 2500; NV4500HD; SB DD; 315/75R16; Spohn Performance 3rd Gen Track Bar; Core 4x4 Adjustable Control Arms; 98-99HD Steering; Spohn Performance Steering Gear Box Stabilizer; 63/65/14; AFC Live; PDD 7mm DV's; 4 GSK; Mac Rack Plug; Custom Fuel System; PDD 5x.012; Colt Cam "Big Stick"; 60# Springs; PDD Stage 1 Push Rods; O-Ring Head; Head Studs; KDP Fix; Fluidampr; Boost/EGT/FP Gauges; BHAF; Interior Modifications
Stox225 is online now
post #4 of 14 (permalink) Old 01-25-2020, 04:03 AM
How did you get the remainder of the stud out without removing the head? Or did you remove the head?
post #5 of 14 (permalink) Old 01-25-2020, 09:10 AM
Stox225's Avatar
Head bolt missing
Because studs only go in hand tight, a reverse bit pulled it out pretty easy. Not sure how a head bolt would come out.
post #6 of 14 (permalink) Old 01-25-2020, 12:03 PM
Chrome's Avatar
Weight reduction.
I'd be willing to guess this will have a domino effect. Better start saving for a gasket and stud set. Its a very easy job to do a cummins head gasket if you have a winch on your ceiling, do it before the heat lifts and warps the head.
2003 Dodge Ram 2500, QCSB, 4x4, Nv4500 w/ mainshaft, Valair clutch, Edge Evo2, AFE Bladerunner, ARP Studs, SRT10 Hood, Sport front, 285 Falkens. Laramie interior. 09 steering. Redhead + Borgenson 275,000 miles and counting + 2013 Ram 5500 4x4 6.7 aisin CC 11' bed
Chrome is offline
post #7 of 14 (permalink) Old 01-25-2020, 12:21 PM
ofelas.5z's Avatar
Any lifting of the head, if at all, would have happened by now.
I wouldn't replace a factory installed head gasket that doesn't leak.
If the bolt can be extracted, clean up the threads, and install a new, oiled factory bolt.
Check the rest of the factory bolts' torque values, and call it a day. Check torque on the replaced bolt after a few heat cycles; easy enough as it's an exposed bolt.
Be easy with the skinny pedal and make sure the coolant is at least warm before driving, until then.
R12 in the summer, Webasto in the winter; cassette tapes & SAE-20078 all year.
ofelas.5z is offline
post #8 of 14 (permalink) Old 01-25-2020, 01:10 PM
Chrome's Avatar
If the bolt can be extracted, clean up the threads, and install a new, oiled factory bolt..
I agree if you can get the bolt out. If.
Whats your opinions on a factory gasket after 280k of wear? I replacement mine unnecessarily when I did my studs at 220k but I dont regret it.
Chrome is offline
post #9 of 14 (permalink) Old 01-25-2020, 01:26 PM
ofelas.5z's Avatar
If the gasket wasn't leaking, I would have bottom tapped & replaced with studs one at a time.
Unless you did head/valve work.
As far as mileage for replacement on a non leaking head gasket - so many variables...EGT, timing & drive pressures being the main influencers.
Studs are definitely easier to remove, as they're not torqued down into the head.
As far as a broken bolt - this is one area I wouldn't skimp on tools - it's well worth the cost to use a screw extractor that will not slip right after the appropriate drill bit, if only to remove user error as a variable.
Since it's an exposed bolt head, easy enough to soak with penetrating oil & apply a torch, if required. Shouldn't be an issue getting a factory bolt out, as they tend to snap off inside the head, rather than inside the block.
post #10 of 14 (permalink) Old 01-25-2020, 04:45 PM
The 10th Man
Cowboy303's Avatar
Location: 12 days north of hopeless, and a few degrees south of freezing to death.
The factory head gasket has been on so long and crushed so tight, from a power holding stand point, I don't think a new gasket will ever seal as well as the factory one, unless you O-ring or fire ring. I'm at 24 on my factory gasket doing 550hp with factory bolts. I doubt a new gasket would ever hold that.
Gandalf the Donkey Hauler - '96 2500 ECLB G56 SB-DD NP241CLD 3.54's, Firerings @ 160ftlb, PDD 4K GSK, PDD 5x18's @ 260, 025's, AFC Live, 28 Cogwheel, AFC Stop-Bolt, HO LP, TPP Manifold Blanket, P&P, Billet 56/64 HX35/GT45 W/Spring gate, EB, OBA, OBP, CC High Idle, BRA, Hotrod PS Pump, Str box brace, SuperSport Headlights, DIY GN Hitch, couple gauges. 733hp/1350tq at NWDC.
Shaughty - '95 2500 RCSB 2WD, PDD 850hp Trans, a lot less than 850hp.
Cowboy303 is offline
post #11 of 14 (permalink) Old 01-28-2020, 11:55 PM
Chrome's Avatar
Assuming a headgasket job is done with studs instead of bolts..
I Thought the purpose of head studs was to get a much firmer hold than stock bolts? Especially since they can be torqued to 150-170 PSI or more without stretching multiple times.
Chrome is offline
post #12 of 14 (permalink) Old 01-29-2020, 09:09 AM
Stox225's Avatar
Depending on what you get, the standard ARP studs is a max of 125 ft-lbs per their instruction. You can go higher, but void any warranty.
