Fuel filter lookup - Dodge Cummins Diesel Forum
 2Likes
post #1 of 15 (permalink) Old 01-18-2020, 01:52 PM Thread Starter
ddurr92's Avatar
Fuel filter lookup
Im look for a no WIF fuel filter . Im still wanting the drain valve. Ive searched different forums and tried what i could with cross references. Ive came to this number ( Fleetguard FS1221 )
Im just wanting to know if this would work for a 1994 cummins 12 valve.
Sent from my SM-N975U using Tapatalk
ddurr92 is offline
post #2 of 15 (permalink) Old 01-18-2020, 02:56 PM
alanack6795's Avatar
Looks too long to me.
But deleting the drain valve gains some room so im unsure.
alanack6795 is offline
post #3 of 15 (permalink) Old 01-18-2020, 06:14 PM Thread Starter
ddurr92's Avatar
Thats the issue im having. I wouldn't think length would be an issue... Because there isnt really anything it would hit i guess..... Any other replies are welcome.
ddurr92 is offline
post #4 of 15 (permalink) Old 01-18-2020, 06:54 PM
It gets pretty close to the fuel pump or the strainer i forget.
post #5 of 15 (permalink) Old 01-18-2020, 07:55 PM
I believe FS1221 will only fit the cast filter housing in the head. The diameter of the filter is not big enough to fit the housings used on p-pumped engines.
I used these filters in my 1st gen.
Sent from my LG-H932 using Tapatalk
hemirunner426 is offline
post #6 of 15 (permalink) Old 01-18-2020, 08:29 PM
On call 24/7
98whitelightnin's Avatar
iTrader Score: 16 reviews
Length is an issue. I cant remember which baldwin, maybe a BF7940, i have but had to use a stack of washers between the filter head and head to get it to fit and it was still a booger. Ive got a wix 33391 with a drain thats going on next.
ddurr92 likes this.
1998 12v, 4x4, Club Cab, Carli, Thuren, BlueTop, Core 4x4, BD Diesel, PDD 5x.012, South Bend
2012 Laramie Longhorn, EFI by Ryan, Carli, Thuren
1995 Dually, Weston's 5x.016, 4k GSK, 5" FloPro, 255/85r16 Toyo M/T, Goerend, ARP, 60# Springs, BW 62/65/14, BW 75/96/1.10, Isspro, Fass 125, BDP Sump, 7mm DV's, 751 HP 1883 FP Torque on NOS
1998 P-Pumped 24v, 4x4, NV4500 swap
98whitelightnin is offline
post #7 of 15 (permalink) Old 01-18-2020, 11:15 PM
FS19519 will fit the filter head but I don't think it will clear the strainer assembly.
post #8 of 15 (permalink) Old 01-19-2020, 07:35 AM
ofelas.5z's Avatar
The FS1221 is M16x1.5
You need a fuel filter that fits an M20x1.5 stud.
R12 in the summer, Webasto in the winter; cassette tapes & SAE-20078 all year.
ofelas.5z is offline
post #9 of 15 (permalink) Old 01-19-2020, 03:28 PM Thread Starter
ddurr92's Avatar
Ohhh. Okay. Im just needing a filter with not WIF sensor port.... Tired of changing orings... Would rather have a drain screw.
ddurr92 is offline
post #10 of 15 (permalink) Old 01-19-2020, 03:30 PM Thread Starter
ddurr92's Avatar
Plus that wix 33391 looks decently priced... Any bad reviews you guys may have? Ive been using a cheapo O'Reilly's filter... For the fuel...and mopar filter for oil.. wanting to change it up a bit.
ddurr92 is offline
post #11 of 15 (permalink) Old 01-19-2020, 03:31 PM Thread Starter
ddurr92's Avatar
Definitely gonna be buying that then.!!
ddurr92 is offline
post #12 of 15 (permalink) Old 01-19-2020, 03:31 PM
pa coal roller's Avatar
I put a bladwin filter on my 96 its 12mircon I think the number is 7079 or 7970 cant remeber but it has no drain I put a new filter on every 3000 to 5000 miles anyways
2012 cc dually 6speed, mini max, cooler delete, h&s intake horn, boost tube,5ich pipe,gdp big line kit Amsoil dealer since 2006
1996 12v 430000 miles. Built trans. 62mm hx 35 90hp injectors
pa coal roller is offline
