96 Ram Transfer case. - Dodge Cummins Diesel Forum
post #1 of 9 (permalink) Old 11-03-2019, 02:31 PM Thread Starter
mdogg54's Avatar
Hello to all, did the 96 Ram 2500 have a shift motor for the transfer case?. was that an option?.
want to get rid of shift knob on floor.
1996 Ram 2500 # 8 TST Plate 240 Hp 605 Tq.
mdogg54 is offline
post #2 of 9 (permalink) Old 11-03-2019, 06:13 PM
The 10th Man
Cowboy303's Avatar
Location: 12 days north of hopeless, and a few degrees south of freezing to death.
no shift motor, that wasn't an option until 03 when they went to the 271 t-case
Gandalf the Donkey Hauler - '96 2500 ECLB G56 SB-DD NP241CLD 3.54's, Firerings @ 160ftlb, PDD 4K GSK, PDD 5x18's @ 260, 025's, AFC Live, 28 Cogwheel, AFC Stop-Bolt, HO LP, TPP Manifold Blanket, P&P, Billet 56/64 HX35/GT45 W/Spring gate, EB, OBA, OBP, CC High Idle, BRA, Hotrod PS Pump, Str box brace, SuperSport Headlights, DIY GN Hitch, couple gauges. 733hp/1350tq at NWDC.
Shaughty - '95 2500 RCSB 2WD, PDD 850hp Trans, a lot less than 850hp.
Cowboy303 is online now
post #3 of 9 (permalink) Old 11-03-2019, 08:25 PM
pa coal roller's Avatar
Yeah and a newer style transfer case wont fit between the frame rails
2012 cc dually 6speed, mini max, cooler delete, h&s intake horn, boost tube,5ich pipe,gdp big line kit Amsoil dealer since 2006
1996 12v 430000 miles. Built trans. 62mm hx 35 90hp injectors
pa coal roller is offline
post #4 of 9 (permalink) Old 11-03-2019, 09:34 PM
The 10th Man
Cowboy303's Avatar
you sure on that one hoss?
post #5 of 9 (permalink) Old 11-03-2019, 09:41 PM
hookit's Avatar
Its close but they fit. Ive heard some guys say theyve had to beat on the frame rail but mine fit with a 1/4 to spare.
one owner '96 eclb dump flatbed. truck and owner are both computer illiterate.
hookit is offline
post #6 of 9 (permalink) Old 11-04-2019, 04:03 PM
I seen a guy try to put one in a 98 and it would not fit. Unless he beat the frame rail in
post #7 of 9 (permalink) Old 11-04-2019, 07:54 PM Thread Starter
mdogg54's Avatar
Hookit can you post pics of this T case and frame rail?. and all mods made to make it work?. Thanks.
mdogg54 is offline
post #8 of 9 (permalink) Old 11-05-2019, 10:40 PM
hookit's Avatar
Im not sure if my setup will help any. My 271 is attached to a zf6. Although center line remains the same, driveline and crossmember etc. wont be close to what you are trying to accomplish. I can take a pic if you want.
hookit is offline
post #9 of 9 (permalink) Old 11-19-2019, 08:41 PM Thread Starter
mdogg54's Avatar
maybe I could just weld on a handle at the transfer case. that would have me to crawl under. or a custom shift lever under the seat.
mdogg54 is offline
