No power change after P7100 adjustments - Dodge Cummins Diesel Forum
post #1 of 16 (permalink) Old 10-09-2019, 12:45 AM Thread Starter
Stevers7012's Avatar
Alright everyone please tell me if this has been posted already but I didn’t see anything. I have a 98 12 valve. I’ve made all the adjustments I can make on the p pump as far as removed the plate, star wheel all the way forward, closed off waste gate on turbo with spring and everything else the how to tune up your p pump instructions say to do......after all that including putting a 125gph FASS fuel system on it, there is no change in power whatsoever and I’m stumped. No smoke either no matter what I do. NOTHING CHANGES. injections have been pop tested. Fuel shut off is adjusted properly. When I put the fuel system in I found that the fuel pump in the tank hasn’t been working, the lift pump was doing all of the work to pull fuel from the tank to the p pump. Egt reads about 900f when full throttle no matter what I do with the injection pump. My boost is about 20 psi. Please tell me someone has had this problem as I’m at a loss.... my next step is buying a new built injection pump but I really don’t have the money for it anytime soon. Also while I’m not pulling anything I am down to 30 to 40 mph by the top of a decent hill with it at full throttle
Stevers7012 is offline
post #2 of 16 (permalink) Old 10-09-2019, 01:01 AM
The Uppity 12v Guy
dauntless89's Avatar
Check the boost reference line and AFC diaphragm.
'95 2500 ECLB 4x4, 334k and paused due to epic transformation in progress.
dauntless89 is offline
post #3 of 16 (permalink) Old 10-09-2019, 02:00 AM Thread Starter
I will check that as soon as I get home this weekend. I didn’t even realize that was something to look into. But of course if that’s the problem it would be a simple one lmao
post #4 of 16 (permalink) Old 10-09-2019, 08:03 AM
GAmes's Avatar
iTrader Score: 7 reviews
There isn't a pump in the fuel tank, the lift pump is supposed to draw fuel and supply the injection pump. You wasted your money on the FASS system. What is your fuel pressure? Your say the fuel shutoff is adjusted correctly. I suggest you double check that. The rod that sticks out on the top of the IP is the other end of the rod the FSS is attached to. With a good light you can see if it is rotating.
GAmes is offline
post #5 of 16 (permalink) Old 10-09-2019, 09:48 AM Thread Starter
So the thing in the tank that I took out and looked at is just the level sending unit? 18 to 20 psi at idle about 36psi at mid throttle and drops to 12psi at full throttle. Could u explain more about the rod on the injection pump please?
post #6 of 16 (permalink) Old 10-09-2019, 10:29 AM
The Uppity 12v Guy
There's a key in there that can fall out. If the key isn't in there the shaft and lever can lose their alignment and cause a low power issue.
post #7 of 16 (permalink) Old 10-09-2019, 10:38 AM Thread Starter
Would you mind sending a picture of the area you’re talking about? I’m working off of memory right now on what the pump looks like and I won’t be home til this weekend.
post #8 of 16 (permalink) Old 10-09-2019, 02:50 PM
GAmes's Avatar
The lever that the FSS is connected to is attached to a rod that has a woodruff key. If the key shears or falls off the shaft will only rotate, if any, as much as the pinch fit allows. The picture of lever is taken from the bottom side. The picture of the rod is from about the same perspective as you can see it from the top.
Name:	FSS linkage.jpg
ID:	858115   Click image for larger version
Name:	Rod on top of p-pump.jpg
GAmes is offline
The Following User Says Thank You to GAmes For This Useful Post:
98whitelightnin (10-09-2019)
post #9 of 16 (permalink) Old 10-09-2019, 07:54 PM Thread Starter
Ok I think I remember seeing that on my pump, that is in the drivers side of the pump correct? Would u care to explain to me how that rod with the key works/what exactly it does? I’m very mechanically inclines but I’ve never messed with the pump at all except for the afc housing
The Following User Says Thank You to Stevers7012 For This Useful Post:
dd453ford (10-11-2019)
post #10 of 16 (permalink) Old 10-09-2019, 08:18 PM
If fuel pressure is dropping off you have a blockage or restriction in the supply. When you installed the FASS system did you bypass the original lift pump? If not check the filter in the lift pump suction.
What are you using for a fuel pickup tube?
With the good pressure low down it would seem the pressure relief valve is working OK but any doubts they are not that expensive.
I guess you have new fuel filters on it.
Cheers Steve
86 F350 CC dually, RTO610, 3.32 final gears 93 5.9 (ex F600) basically stock,THD pin, Aftermarket AFC spring, re-set injectors. tuning in progress
Blackduck59 is offline
post #11 of 16 (permalink) Old 10-09-2019, 08:23 PM Thread Starter
With the good pressure low down it would seem the pressure relief valve is working OK but any doubts they are not thatexpensive.
Cheers Steve
Yes I bypassed the lift pump altogether straight from the tank to the IP. I used the draw straw that cane with the pump. I changed the relief valve out already also.
post #12 of 16 (permalink) Old 10-09-2019, 09:54 PM
If it were me Id chuck the fass, remove fuel heater and re install the mechanical lift pump.
Your asking questions about the pump that you should know before you touched it. You should have no issue getting good power from the pump. Either watch more videos and do more reading about how the afc works or get someone else to do it. You can leave the plate in and grind it.
The key on the shaft joins the shaft and the linkage. It can fall out if you take it apart as its hard to see. You can also zip tie your fss up to see if its part of the issue. You should see much more boost then you are.
Also you should get a set of 3k/4K governor springs for the pump.
Read read and read more on how the afc works. And also the pump. Its simple but complex lol
Aburdett is offline
