Kinda hard start white smoke bad timing leaky injector? - Dodge Cummins Diesel Forum
post #1 of 4 (permalink) Old 09-15-2019, 12:59 PM Thread Starter
Sawlezall's Avatar
So I bought this 95 12v the guy says it has a zero fuel plate and modified afc houseing it’s a 12mm stroker pump timing is advanced to 18degrees but it's been smoking during the first start of the day and then yesterday I went into the store to get somthing real quick came out and its smoking a little at idle and when I'm driving down the road and when the boost kicks in it wants to chuck out a plume of whitish grey smoke any idea? When I test drove it ran great no white smoke only the normal black smoke doesn't seem to be down on power or anything
Sawlezall is offline
post #2 of 4 (permalink) Old 09-15-2019, 01:57 PM
Does the smoke smell like antifreeze? Or make you tear up like Unburnt diesel?
Sounds like itís evident when the truck cools down a bit. Ie startup or idling. If thatís the cause Iíd prob lean more to compression.
Aburdett is offline
post #3 of 4 (permalink) Old 09-15-2019, 02:01 PM Thread Starter
Sawlezall's Avatar
It doesn't seem to smell sweet and doesn't seem like fuel has been getting to the oil levels pretty steady I forgot to say I just changed the fuel filter and coolant isnt oily either
post #4 of 4 (permalink) Old 09-15-2019, 02:02 PM Thread Starter
Sawlezall's Avatar
Seems more like just unburnt fuel from what I can tell like possible injector leaking but this is my first diesel I've owned but know how to wrench read alot of post but nothing that seems to be spot on with what's going on with mine
