Noise apon start up - Dodge Cummins Diesel Forum
post #1 of 8 (permalink) Old 08-17-2019, 09:58 PM Thread Starter
Noise apon start up
Hello everyone quick question 97 2500 4x4 manual trans 262000 miles upon start up for like 3 seconds is a distinct sound like a bag of change or a dry clutch on a motorcycle something of that nature does anyone have that problem or no what it might be thankyou
702 3500 is online now
post #2 of 8 (permalink) Old 08-17-2019, 10:25 PM
the man in black's Avatar
Is this truck new to you? If not how long has it made this noise? What clutch do you have? Have you checked trans fluid?
Scooty Puff Sr - 2016 3500 CCLB
Truckasaurus - 2010 2500 CCSB -sold
the man in black is offline
post #3 of 8 (permalink) Old 08-18-2019, 01:53 AM Thread Starter
yes the truck is new to me I bought off of older gentleman dont no what clutch but he said that he replaced it like last year with a cheaper clutch said he spent like 500 on it said the better ones were to hard for him to engage flywheel was resurfaced also said the fluids were up to par he was a honest man so I believe him just haven't got around to change it could it be the throw out bearing I'm kinda a newbie
post #4 of 8 (permalink) Old 08-18-2019, 02:08 AM Thread Starter
Also the transmission is the original with original syncros only thing he did to it was fix the 5th gear nut when it went out on him said that everything looked good inside tranny that there was no need to change out anything
post #5 of 8 (permalink) Old 08-18-2019, 03:01 AM
Does it do it everytime you start? Warm and cold?
Start my disconnecting the turbo from the intercooler. Start the truck and see if the noise is gone. If it still persists then it's not junk bouncing around in the IC.
I would imagine it is in the tranny if the turbo disconnect doesn't do the trick. Could also be the starter.
98 12v SC 4X4 114K Miles, A5K, SDX 5X18, 4K GSK, KDP, Custom VB, Deep Pan, Peak Diesel IC/B, Devils Own W/M, Head Studs, 60lb VS, 2095 Rack Plug, Barrels moved, Guages (EGT, Boost, Trans Temp), Timed 22* http://s1057.photobucket.com/albums/t398/lwilde13/
nSaEvAyL is offline
post #6 of 8 (permalink) Old 08-19-2019, 01:33 AM
Is the starter hanging up on the flywheel for some reason?
1995 RAM 2500 Club Cab Laramie SLT 2 W/D 5.9 P-Pump w/ NV4500 3.54 Dana 80. Nearly stock. Timed @ 15.5* Currently 318,000 miles and counting.
dd453ford is offline
post #7 of 8 (permalink) Old 08-19-2019, 10:11 PM Thread Starter
Thank you guys I will check all the stated troubleshooting advice you have gave me
post #8 of 8 (permalink) Old 08-20-2019, 02:00 AM
myother4x4isaCJ7's Avatar
Maybe take a video of it? Iíll bet itís the starter, my truck always had a similar noise and when I replaced the starter it went away.
myother4x4isaCJ7 is offline
