12v Cummins knock after pulling. - Dodge Cummins Diesel Forum
 1Likes
  • 1 Post By Truefat
post #1 of 11 (permalink) Old 08-12-2019, 05:07 PM Thread Starter
I have swapped a 12v into a 89 chevy c30. I was pulling my camper up a hill and as I went to shift from 5th to 4th the truck sounded funny. I pushed the clutch in and the truck died. I tried to start it and the motor just maybe turned over once but then the starter just ticked. I had to pop the clutch to get the truck to start. Well I pull over and check everything I noticed some blowby more than normal but the oil level was fine. The egt was at 1100-1150 pulling up the hill I never lost oil pressure and fuel pressure was normal. Every since then I have developed a knock. I drove the truck all the way home over an hour drive pulling a camper. I get the truck home and turn it off. Go out to check it the next day and the knock is a lot louder. I thought it might be injectors so I pull them and have them tested and the guy said that I needed new ones that a couple were sticking and recommended 6 new nozzles. I took this opportunity to buy Industrial injection 80hp injectors and installed them yesterday and that did not help. Knock was still there and just a loud. I decided to drive the truck down the road to a diesel mechanic to have him look at it and by the time I got there the knock was no where as long as when I had started it this morning. Im guessing that getting the truck warm has something to do with quieting the knock down. Tomorrow I plan to remove the valve covers to get rockers. I am wondering if I have spun a bearing. What makes me think its not a rod is it should have blew by now after towing a 7500lb airstream over an hour home. I have pushed the prime on the lift pump making sure that it hadn't wore but it didn't change the sound. What else could I be looking at? only thing that is done to the truck is a ground fuel plate and blocked wastegate and now new injectors.
Volunteer93 is offline
post #2 of 11 (permalink) Old 08-13-2019, 12:04 AM
Sounds like a bent rod or slipped timing. Check both and report back.
98 12v SC 4X4 114K Miles, A5K, SDX 5X18, 4K GSK, KDP, Custom VB, Deep Pan, Peak Diesel IC/B, Devils Own W/M, Head Studs, 60lb VS, 2095 Rack Plug, Barrels moved, Guages (EGT, Boost, Trans Temp), Timed 22*
nSaEvAyL is offline
post #3 of 11 (permalink) Old 08-13-2019, 05:07 PM Thread Starter
I will do. It will take till the weekend to pull the motor. Today I checked the valve lash and every thing there seemed fine. I went and bought a bore scope and will check the cylinders tomorrow and let you know.
post #4 of 11 (permalink) Old 08-13-2019, 06:51 PM
Stox225's Avatar
How does slipped timing cause a knock? It cause backfiring sounds as you rev the engine and produces a crap ton of white smoke.
Itís possible some valves loosened up. Whenís the last time you did a valve lash? How oldís the engine? Need some more background information on the engine.
1997 Cummins 2500; NV4500HD; SB DD; 315/75R16; Spohn Performance 3rd Gen Track Bar; 98-99HD Steering; 63/65/14; AFC Live; PDD 7mm DV's; 4 GSK; Mac Rack Plug;
; PDD 5x.012; Colt Cam "Big Stick"; 60# Springs; PDD Stage 1 Push Rods; O-Ring Head; Head Studs; KDP Fix; Fluidampr; Boost/EGT/FP Gauges; BHAF
Stox225 is offline
post #5 of 11 (permalink) Old 08-13-2019, 10:15 PM
Truefat's Avatar
My guess is you overheated a piston because you waited too long to downshift. The knocking is probably the wrist pin.
1998 2500HD Laramie SLT 4x4 12v QCSB 5 spd 3.55 200k stock
2004 2500 Laramie 2wd 305hp QCSB 6spd 3.73 200k stock
Truefat is offline
The Following User Says Thank You to Truefat For This Useful Post:
dd453ford (08-15-2019)
post #6 of 11 (permalink) Old 08-13-2019, 10:48 PM Thread Starter
I would say you are right. Ill post back tomorrow. I am going home and checking after work tonight.
post #7 of 11 (permalink) Old 08-13-2019, 10:57 PM
Im not sure why we went immediately to wrist pin failures, bent rods, and failed bearings...
Did the engine overheat during your tip? Has it been overheated before?
If no, then there is a better chance than not the bottom end is fine.
First thing I would try is to figure out what hole it's coming from. I would start by figuring out if it's a fueling issue. Crack each injector one by one at idle and see if it goes away. If it does, swap that injector into another hole. If the knock moves you've found the bad injector. If the knock doesn't move then you know which cylinder it is and now you can perform some inspection of that cylinder, it's valve train, and possibly that barrel on the P7100.
I know you say the nozzle was replaced but a new nozzle does not equal a new injector. You injector guy could of missed something in the body that is the source of failure. Swapping holes will point to a bad injector if that's the case.
Sent from my LG-H932 using Tapatalk
hemirunner426 is offline
post #8 of 11 (permalink) Old 08-13-2019, 11:21 PM
Truefat's Avatar
The fact that the engine died when he pushed in the clutch and then the starter couldn't turn it over were the key issues that don't make sense except for a partially seized piston
Custom_billet likes this.
Truefat is offline
post #9 of 11 (permalink) Old 08-14-2019, 12:29 AM
Custom_billet's Avatar
I agree. It sounds like a melted piston. Listen to some youtube videos on these motors with a bad piston. Sounds like a knock.
2007 Dodge 5.9 3500 CC 4X4 dually. S&B intake, Diamond Eye 4", Pacbrake, Edge CTS2, Anarchy EFI live. Updated 1 piece aluminum drive line.
Custom_billet is offline
post #10 of 11 (permalink) Old 08-14-2019, 12:49 AM Thread Starter
I agree on the piston. I only looked in #6 with a bore scope. I'll try to attach some pictures but it doesnt look melted but scratched pretty bad. I apologize for the bad pics. I guess I'll start pulling the head tomorrow.
ID:	854065   Click image for larger version
ID:	854067   Click image for larger version
post #11 of 11 (permalink) Old 08-14-2019, 10:49 PM
Looks like I skipped over that for some reason. The pictures tell the story.
It will be interesting to find the reason for failure.
