South Bend Clutch ? - Dodge Cummins Diesel Forum
 2Likes
post #1 of 16 (permalink) Old 07-28-2019, 08:16 PM Thread Starter
On call 24/7
98whitelightnin's Avatar
iTrader Score: 16 reviews
South Bend Clutch ?
Im going to order a clutch in the next couple days and want to get a good streetable double disk. I put a Valair DD3800 ceramic in and that clutch held everything that I could ever throw at it, including many hooks to a sled, but I hate the jerky 2nd gear take off. Im looking at a South Bend DD multi friction (SDD3250-5 and the all organic DD SDD3250-5-ORG. I will never hook to a sled but do travel through the big city daily and want a smooth empty 2nd gear take off or towing my 32' enclosed trailer.
Who has one of these and what is your take? @jkidd
1998 12v, 4x4, Club Cab, Carli, Thuren, BlueTop, Core 4x4, BD Diesel, PDD 5x.012, South Bend
2012 Laramie Longhorn, EFI by Ryan, Carli, Thuren
1995 Dually, Weston's 5x.016, 4k GSK, 5" FloPro, 255/85r16 Toyo M/T, Goerend, ARP, 60# Springs, BW 62/65/14, BW 75/96/1.10, Isspro, Fass 125, BDP Sump, 7mm DV's, 751 HP 1883 FP Torque on NOS
1998 P-Pumped 24v, 4x4, NV4500 swap
98whitelightnin is online now
post #2 of 16 (permalink) Old 07-28-2019, 08:27 PM
Destroked 450's Avatar
Have you talked to Valair about their organic disc and lighter plate to use with the flywheel you already have?
Mine-04 F-450 SCFB 4X4 drw,5.9 12v 215 Ppump,ZF 6,KYclutch,KDP fixed,gauges,5x12's,15deg,3k GSK,60#,AFC Live, Super B single,Pusher intake,D celebrator brake,07 coil spring front conversion.
Her's-18 F-150 STX SC, 4x4, 5.0
Toy- 64 Fairlane, future 406FE, 3 Holley 2bbls, 4 spd
Destroked 450 is offline
post #3 of 16 (permalink) Old 07-28-2019, 08:46 PM Thread Starter
On call 24/7
I installed that clutch in my old 98 24v, this will be going in my current 98 12v.
post #4 of 16 (permalink) Old 07-28-2019, 08:52 PM
the man in black's Avatar
I have the valair organic DD in my truck and was in my last truck. It's worth considering. I dont daily but do drive threw town on the weekends and tow regularly. Very smooth clutch. Also read great things about the south bend. Dont think you'll go wrong with either. I also beat the snot out of both trucks. No sled pulls but pretty aggressive driving with 15k in tow regularly. My 10 had an s464 even. Still held great.
98whitelightnin likes this.
Scooty Puff Sr - 2016 3500 CCLB
Truckasaurus - 2010 2500 CCSB -sold
the man in black is online now
post #5 of 16 (permalink) Old 07-28-2019, 09:04 PM Thread Starter
On call 24/7
I was originally going to go with Valair but thought id give Southbend a try this time. I havent completely ruled out Valair organic though
post #6 of 16 (permalink) Old 07-28-2019, 09:09 PM
I'm not a man found of change. It was a leap for me to go with valair over south bend but now I'm hooked on them. After the beating my 10' got I'll never change at this point.. Again not saying anything poor about south bend. Many highly praise them as well. The 3250 would have been my choice if I didnt get the valair the first time around.
post #7 of 16 (permalink) Old 07-30-2019, 12:25 AM
rcmac's Avatar
I have had a 3250 since 2012, at the time I think they called it their street version. I have about 40K on it with various driving styles (stop and go, towing, highway). Its very quiet, not jerky and I tow often with it. If I was in the market for clutch I wouldn't hesitate buying another.
SB 3250 1 3/8", Arp625, 60lb springs,188/220,hd pushrods, 4gsk, bosch race 2 120hp sticks, #10, 191, ats 3 piece, r700's, 19*, arp rod bolts/main studs, ad165, o ring block, balanced pump, balanced bottom end
rcmac is offline
post #8 of 16 (permalink) Old 07-30-2019, 09:55 AM Thread Starter
On call 24/7
I think im going to order the organic. This truck will most likely never be over 450hp and I want a smooth take off.
post #9 of 16 (permalink) Old 07-30-2019, 09:29 PM Thread Starter
On call 24/7
Ordered a SDD3250-5-ORG from Diesel Auto Power today.
post #10 of 16 (permalink) Old 07-31-2019, 01:36 AM
Posting Suspended
That's what I am running and my truck is a 700hp compound towing machine. Never had any problems. Love that clutch. Mark the way it is assembled when you get it. So when installing you don't mess up the direction everything faces. They paint them but it doesn't do any good.
nSaEvAyL is offline
The Following User Says Thank You to nSaEvAyL For This Useful Post:
98whitelightnin (07-31-2019)
post #11 of 16 (permalink) Old 08-08-2019, 07:36 PM Thread Starter
On call 24/7
Got the SB DD organic clutch in today, Standard Gear and Transmission in Ft Worth did the install. My stock hydro's and stock style clutch had higher plate load than this 3250 but the shop said my stock hydro's were shot. They are a master distributor and had the hydro's in stock. I never put much thought into SB or Valair hydro's but wow, this pedal has never felt better and even though its a dual disk, its just as quiet as a single! I still have several hundred miles for break in but im sold on SB.
post #12 of 16 (permalink) Old 08-08-2019, 09:57 PM
Good to hear. It should last you many many years and miles.
